are 88 crx and 89-91 crx rear control arms interchangable?
Old 10-16-2009, 12:13 PM
db8db8db8's Avatar
Default are 88 crx and 89-91 crx rear control arms interchangable?
I am currently running 88 rex w/ factory suspension. I wanted to know if anyone out there has swapped 89 - up rear LCA in place of the 88 itr style LCA?
Old 10-16-2009, 12:37 PM
90da4dr's Avatar
Default Re: are 88 crx and 89-91 crx rear control arms interchangable?
That's funny, I just asked the same question in my thread.
Old 10-16-2009, 12:38 PM
Keyboard Humorist
4drEF's Avatar
I did the opposite - swapped my 91's out for the ITR's.
Direct swap with perfect fit.
Just need the correct shock.
Old 10-16-2009, 12:48 PM
90da4dr's Avatar
your was a 91 originally though
Old 10-16-2009, 12:51 PM
Keyboard Humorist
4drEF's Avatar
Yes... 91 was originally 'fork' style shocks.
Converted to ITR 'box' LCA's so I could run 'eye' mount shocks.
The geometry is the SAME from end to end.
The only notable change is the design scheme used for mounting the shock.
Old 10-16-2009, 01:07 PM
90da4dr's Avatar
I see what your saying, 88 and itr's are the same. If thats the case then the lower control arms should be interchangeable.
Old 10-16-2009, 01:24 PM
Tyson's Avatar
yes.
Old 10-16-2009, 04:35 PM
db8db8db8's Avatar
so theres no disadvantage or advantage. it pretty much mounts on with a fork style 89-91, vs 88, itr style. same geometry. awesome! so I shouldnt have a prob swap'n the two. Thanx for the info peeps!!!
Ryan Lantz
02-16-2014 07:25 PM
Skipper75
Suspension & Brakes
04-20-2007 07:54 AM
Skipper75
04-16-2007 06:48 AM
ecsahs3
07-07-2004 10:59 PM
rasta420
10-24-2002 10:18 PM
Quick Reply: are 88 crx and 89-91 crx rear control arms interchangable?
