88-91 hydro conversion using clutch master cylinder from 92+ civics
Old 02-10-2008, 11:03 PM
alpha_1's Avatar
Default 88-91 hydro conversion using clutch master cylinder from 92+ civics
yes i know they make hydro tranny conversion kits for the cable tranny but what i want to know is that does anyone in here have pics on how to do a conversion using they 92+ civic clutch master cylinder and pedal? i've read that someone did it but i would like a good write up with pics if possible on how to install the clutch master cylinder to the wall. also will the pedal bolt up or do i have to mod it to fit? i have read that people are having trouble with cable conversion kits and i would prefer trying to do this conversion or should i just by a hydro conversion kit and save me some time? please help me out and let me know.
Old 02-11-2008, 05:50 AM
ComeOnKip's Avatar
Location: Where the wild things are in, NY, United States of America
the pedals swing a different way. The ef pedal pulls a cable while the EG pedal pushes a CMC piston. You could figure out a way to do it with using a small MC mounted on the other side of the bracket inside the chassis and then run it through a bulkhead to the wall. Is there anyway to do this without a welder / drill press? no. Is there an easy way to do it? no. Search around, I was on a kids thread not but a week / 2 weeks ago where he mounted a CMC inside the cabin.
Old 02-11-2008, 07:04 AM
s1267712's Avatar
Default Re: 88-91 hydro conversion using clutch master cylinder from 92+ civics (alpha_1)
It actually is not a bad idea to use the eg master cylinder and peddle! The clutch pedal assembly is seperate on the eg civics, so it might work pretty good. Pick one up at a junk yard and let us know how/if it will wor out
Old 02-11-2008, 07:06 AM
dr_latino999's Avatar
Default Re: 88-91 hydro conversion using clutch master cylinder from 92+ civics (s1267712)
You'll have to cut a hole in your firewall to clear the 92-00 setup in its native form.
Old 02-11-2008, 10:43 AM
b16a1eg6's Avatar
Default Re: 88-91 hydro conversion using clutch master cylinder from 92+ civics (dr_latino999)
This guy did it with all aftermarket stuff...
http://www.theoldone.com/artic...c.htm
Baldb4thirty
05-02-2010 03:27 AM
Baldb4thirty
Welding / Fabrication
04-26-2010 05:46 AM
Clipsed
12-09-2008 11:33 AM
Dancing is Forbidden
12-30-2003 10:58 PM
Quick Reply: 88-91 hydro conversion using clutch master cylinder from 92+ civics
