88 and 89-91 crx, are there any diff. in the front struts?
Old 04-07-2003, 05:27 AM
New User
auto-x's Avatar
Default 88 and 89-91 crx, are there any diff. in the front struts?
im ready to order a set of tokico illumina for my 88 crx with 90-93 integra lca. should i get a set for 89-91(front and rear) or a pair of 88 fronts and a pair for 89-91 rears? I appreciate your expert opinion. -rico
Old 04-07-2003, 05:47 AM
JoshDM's Avatar
Default Re: 88 and 89-91 crx, are there any diff. in the front struts? (gude boi)
they do have different part numbers from honda, but they should interchange anyway.
Old 04-07-2003, 06:35 AM
Mr Furball's Avatar
Default Re: 88 and 89-91 crx, are there any diff. in the front struts? (JoshDM)
ok, The 88-89 are the same, As same with the 90-91. Order what ever year you have, if you have 88-89 up front, thats what you order, If you have 90-91 in rear, that's what you order.
88-91 are interchangeable but 88 parts will not work with 91 parts, you have to change everything over to either year. hope this helps. But both will work
Old 04-07-2003, 07:16 AM
New User
auto-x's Avatar
Default Re: 88 and 89-91 crx, are there any diff. in the front struts? (FURBALL B-16)
the second reason i ask this question is it will be cheaper to order a set of front and rears from the same car than 88 fronts and 89-91 crx /93 integra rears. if theres no difference between 88 and 89-91 fronts then i will order the 89-91 front and rears. by the way, the 89-91 crx rear struts will work with 90-93 integra rear lca. thanks again.
Ryan Lantz
02-16-2014 07:25 PM
repingjdm
11-05-2010 01:23 PM
Eee Pee
11-01-2003 10:21 PM
dough-boy
09-07-2003 12:11 PM
ruiner17
05-11-2003 12:39 AM
Quick Reply: 88 and 89-91 crx, are there any diff. in the front struts?
