1991 honda ef sedan clutch cable adjustment
Does anyone know how to adjust the clutch cable, i have a problem i cant put it in gear only when the engine is not running. So i think it needs an adjustment on the clutch cable.Has anyone had a problem, like this.
PHANTOM MENACE
Re: 1991 honda ef sedan clutch cable adjustment
There's a **** on the cable itself where it attaches to the transmission [bracket]. Turn the **** to tighten, you'll see the clutch lever move upward.
PHANTOM MENACE
It's going to "feel" tight no matter how someone explains it with words. You can turn it a few turns at a time and try shifting with the engine running until it works.
I adjusted it already and I still can put it in gear when the engine is running. So I don't thing that's the problem, do you know what else it can be?
hatchinprogress
02-15-2006 10:22 AM
