1991 CRX Si - Cranks but won't start.
Old 06-08-2010, 11:22 AM
persianp's Avatar
Default 1991 CRX Si - Cranks but won't start.
So my CRX has been dead for nearly two years. I recently started working on it. When I garaged it, I could turn it on but had to keep the gas pedal depressed so it would keep on.
After doing research I found the common problems were bad ignitor, ignition coil, or main relay. The main relay definitely is working. I've tested it and can hear it "click" on when I put the key in. Also I can smell the fuel being delivered to the engine when I crank her up.
So I tested the ignitor and it seemed like it was bad, so I replaced that. Also replaced the distributor cap and rotor. Nope. That didn't do the trick. So I tested for spark and had none. I thought, bad ignition coil, tested it, it seemed fine. But I still went out and replaced it. That didn't work, still no spark. The engine just cranks.
So then I returned the ignition coil, and got a refurb distributor. Installed that (I haven't done any timing adjustments) and now the puppy almost starts...which is more progress than before. It's like it's trying to turn on, and I can feel the engine almost catching, but it doesn't ever fully get going.
Should I adjust the timing? Is it even possible without the engine turning on? What should be the next step? Also, I can provide more details if this wasn't enough. (Battery is fine as I just purchased a new one).
Thanks.
Old 06-08-2010, 11:34 AM
sirtef9's Avatar
Default Re: 1991 CRX Si - Cranks but won't start.
loosen the distributor so you can adjust, have someone try and start it while you go forward or backwards, if it starts with it all the way one way then your timings a tad to far. Readjust to specs start and be happy.
Old 06-08-2010, 11:54 AM
D16SiHatch's Avatar
don't bother fartin around with the ignition timing just yet. put the distributor in the center of its adjustment range and then go check your mechanical timing.
Old 06-08-2010, 01:06 PM
persianp's Avatar
Hey guys, both your suggestions worked. When I tried adjusting the distributor to its max range it wouldn't start. When I put the distributor in the middle it turned on and stayed on! Now it's running like an actual car. Adjusted the timing, now just need to change the oil and take her to the closest gas station for a wash. Yes!
Old 06-08-2010, 01:44 PM
D16SiHatch's Avatar
good to hear man
Old 06-08-2010, 06:02 PM
Lennart89's Avatar
congrats!
drock4688
10
08-23-2008 10:59 AM
90crxdxb16
11-17-2006 03:54 PM
erik92DA
06-08-2006 08:16 PM
bmg123
09-25-2005 12:33 AM
blakryder1
09-11-2004 10:04 AM
Quick Reply: 1991 CRX Si - Cranks but won't start.
