1990 civic ef with idle problems
Old 12-14-2009, 09:48 AM
GreenGoblinEF's Avatar
Default 1990 civic ef with idle problems
i gotta 1990 civic ef that when im idling the engine revs up and down sounds like breathing problems but only when im idle.. and i have no clue what it could be i have never dealt with this problem before so if u have some helpful information please let me know.
Old 12-14-2009, 09:52 AM
zeb1117's Avatar
Default Re: 1990 civic ef with idle problems
vacuum leak?
Old 12-14-2009, 09:53 AM
4g4dcruisin's Avatar
answer these questions first...
-what type of motor?
-what is your idle at start up, and what does it fluctuate between? (i.e. 500-1000rpm)
-have you recently added/flushed coolant from the radiator?
-have you removed/replaced any sensors on the intake manifold or carbeurator?
-finally, i know you said only at idle, but when you accelerate, does it fluctuate at all during this time? kind of like if your stepping on the gas pedal repedely.
Old 12-14-2009, 07:17 PM
- stock d15
-no tack
-no
-no
-and no only during idle
but i will definitely check these things out and get back to you thanks!
Old 12-14-2009, 09:52 PM
t3601's Avatar
start pinching vaccuum lines rite off of the manifold until the problem stops. if it's not a vaccuum leak make sure your throttle cable isn't too tight, it needs to have a little slack in it, if not your tps will not be at 0, so the computer will start ****ing with it trying to compinsate for it, and it will do exactly what your describing.
Old 12-15-2009, 02:30 AM
90JDMCIVIC's Avatar
At idle does the idle go up then down repetedly if so could also be your Idle Air Control Valve (IACV) located behond the throttle body.
here's a link with picture to show you what i mean and a link how to clean it.
http://media.photobucket.com/image/h...cture_3678.jpg
video
http://www.youtube.com/watch?v=tUkCCwqU3eU
I think by the way you describe it below
http://www.youtube.com/watch?v=rwwgw...eature=related
Let me know man hope that helps.
Old 12-15-2009, 11:17 AM
4d_ef_bucket's Avatar
i had too clean my iacv a few days ago it was easy
Old 12-23-2009, 03:45 PM
thanks for all the info guys but it didnt work and i also did the same thing on my si but now my si has idle problems? i cleaned the iacv and the throttle body and now my si has idling issues im stumped any other suggestions?:S
Old 12-23-2009, 05:25 PM
chivid's Avatar
check the fast idle valve. its connected on the side of the throttle body and theres a hole inside the throttle body that manages the fast idle valve to maintain a steady idle. to check this stick you finger over one of the holes inside the throttle body. theres should be two holes. one the MPFI systems its on the bottom inside the throttle but the DPFI could be either the top or bottom(im not sure). try it
Old 12-23-2009, 05:41 PM
89s1's Avatar
Lots of half-right info in here....
stock 90 dx has no fast idle valve, and the IACV isn't behind the intake on the dx, its on the drivers side furthest runner of the intake manifold. the farthest right when looking at it from the front.
Old 12-23-2009, 11:33 PM
BiG ChOr!Zo's Avatar
http://ef-honda.com/ben/Badidle.php
Old 09-28-2014, 09:04 AM
Mr.Galloway's Avatar
Vacuum leak
chope045
10-24-2011 04:12 PM
rsa0905
02-27-2010 07:01 AM
JDM-KIDD
08-04-2009 05:22 AM
Singlecam4dr
11-11-2007 04:00 PM
Quick Reply: 1990 civic ef with idle problems
