1989 civic timing belt change
Old 07-14-2007, 04:00 PM
89hatch408's Avatar
Default 1989 civic timing belt change
So im trying to change my timing belt and the crankshaft pulley is giving me some trouble, i know there is a tool for this very problem but that is unavailable to me right now, so my question is, is there any way to get the pulley bolt loose without using that tool or and impact gun?
Old 07-14-2007, 04:56 PM
boosted timebomb's Avatar
Default Re: 1989 civic timing belt change (89hatch408)
is the motor still in the car or do you have it out
Old 07-14-2007, 05:02 PM
gator88's Avatar
put person in car, have them put the tranny in 5th gear, no other. Have them hold the brakes, while you slide around the front of the car. With ur breaker bar pointed towards the ground, hold under the bumper (to keep from pushing urself backwards) and push as hard as ur *** can with ur leg(s) mine broke free pretty easily with this approach once my impact wouldnt move it. also, use shortest extension you possibly can to reduce flex and stuff. I used a 3/4" breaker bar that is about 2 feet long, adapted to a 1/2", then my impact socket (shallow) this was short enough to not flex andwas barely out past the crank pulley.
If the motor is out of the car, haul it to a tire place/truck shop. They will have an impact to break that bitch loose.
Old 07-14-2007, 05:25 PM
89hatch408's Avatar
Default Re: 1989 civic timing belt change (gator88)
the motor is in the car, and also its a 4 speed theres no 5th gear but ill try that in 4th and see how it goes
crvglenn
Honda CR-V & Element
08-20-2017 01:44 AM
AudioFunk
03-07-2014 09:16 PM
brokenagain
02-21-2011 10:36 PM
stevescivic
07-23-2004 06:42 PM
crxcess
02-19-2004 08:24 PM
Quick Reply: 1989 civic timing belt change
