1988 Honda Civic DX Ignition Diagram [Request] - Honda-Tech
Old 01-21-2011, 12:22 AM   #1
Arseezy's Avatar
Default 1988 Honda Civic DX Ignition Diagram [Request]
I used the search but I'm still clueless, and I need it somewhat "Dumbed down"
I'm trying to wire a push button start in my EF, but I want to make it so the only way the engine will crank is through pressing the button.
So basically what I need dumbed down is, what wire do I cut and wire to the button?
Lolol thanks :]
Arseezy is offline   Reply With Quote
Old 01-21-2011, 08:27 AM   #2
tonythetuner®'s Avatar
Default Re: 1988 Honda Civic DX Ignition Diagram [Request]
It will be the thick black wire with the white stripe. Cut it add the switch. But make sure it is a high amp switch a lot of current goes threw that wire. And that's all you need to do for the push button start. note car will no longer crank with the key you must put key to the "on" position. And push the switch to crank it.. or you could splice in to the acc power wire don't cut it just splice in to it and add a wire to run to the switch and from the switch run a wire to the starter wire and splice into it. That way you can still start it with the key if you want.. and the push button
tonythetuner® is offline   Reply With Quote
Old 01-21-2011, 08:27 AM   #3
lunalink's Avatar
http://www.spoonertuner.com/manuals
Download and have fun
lunalink is offline   Reply With Quote
NRG QR + 1 wire horn button = HELP! cmross13 Honda CRX / EF Civic (1988 - 1991) 10 02-27-2010 12:39 PM
Door lock not working, which parts to buy? lv6l Acura TSX 9 10-27-2009 11:18 AM
wiring horn button (not on steering wheel) kleen98accord Audio / Security / Video 8 12-06-2007 08:44 PM
Put in a new radiator now the horn doesnt work!! WTF?!?! phanatic Honda Civic / Del Sol (1992 - 2000) 1 10-31-2005 06:35 AM
i need a run down on building an LS vtec E-spec Tuner All Motor / Naturally Aspirated 7 09-06-2003 12:04 AM
Tags
1988, 88, 90, 98, american, civic, crx, diagram, ef, honda, ignition, output, switch, wirelocation, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
