1988 Crx Si check engine light help. - Honda-Tech
Old 10-02-2012, 09:59 PM   #1
Default 1988 Crx Si check engine light help.
Ok, I have a 1988 CRX Si thats throwing a code 1 light. I just recently rebuilt and replaced the D16a6 in it using the motor and tranny from a 1991 Civic Si. Ive tried two different o2 sensors both new, a different ECU, two separate exhaust manifolds (DC Sports and Pace Setter). I thought that maybe the o2 sensor wasn't getting hot enough when it was relocated to the b pipe (DC Sports) since its not heated and wasn't working properly so I switched to the Pace Setter which has a closer o2 sensor location (more like stock).
I've double checked all the parts to make sure they are correct for a CRX and have searched the web for solutions. The motor isn't running rough, very smooth and the fuel pressure is correct according to Honda so i don't think its a fuel pump or injector issue. The only thing is it appears to be running rich because I'm getting horrible gas millage.
Any ideas/solutions? Any feedback would be great. Thanks in advance!
CrxSiVtec8 is offline   Reply With Quote
Just completely failed smog at 15mph tayone415 Honda Civic / Del Sol (1992 - 2000) 22 01-22-2014 11:22 PM
86 si hard start and bad mpg kegan88 Classic Hondas 2 12-30-2011 11:49 AM
Failed smog in california Atomic_EF9 Honda CRX / EF Civic (1988 - 1991) 3 07-02-2011 11:12 PM
Pace Setter headers any good?? mario-SI-08 Honda Civic (2006 - 2015) 16 06-14-2008 08:09 PM
Pace Setter? Live_Love_Burn_Die Honda CRX / EF Civic (1988 - 1991) 16 05-07-2004 11:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
