12v Ignition source for power windows?
Changed a bad ignition switch on my crx and the previous owner had the power wire for the windows tapped into the ignition harness. Is this an okay method? Or should I be rewiring it differently? If i'm going to do it the same way what color wire do i need to tap into on the harness? Should be the black/yellow wire correct?
Re: 12v Ignition source for power windows?
Use the 3 accessory power ports in the fuse box. Three squares with male spades. One is constant, ignition, and headlights. Easy to figure out which.
0TT
12-31-2007 11:49 AM
jadugartir
05-22-2005 01:26 PM
mugenracer
Audio / Security / Video
04-03-2004 05:50 PM
