[FAQ] D Series Torque Specs for everyone - Honda-Tech
Old 03-05-2005, 12:50 PM   #1
SOHCEK-Turbo's Avatar
Default [FAQ] D Series Torque Specs for everyone
This is for everyone, I made this torque spec thread since I and many others here always ask about torque specs. Plus I myself, find myself looking trough all my Haynes and Chilton books for torque specs while I know I can make a list like this one to make it easier. I hope this can be some help and it can be made a sticky on these boards.
These torque specs are straight from the Chilton and Haynes manuals. I might also add some ARP torque specs as well. I still need to add more as you can see Ive been a little busy so as soon as I can I will add more. I would also be cool if others can add to it as well.
ALL TOQUE SPECS ARE IN FT-LB.
A/T Tranny Drain plug......................... 29
M/T Tranny Drain and fill plug..............30-40
Wheel Lug Nuts....................................80
Fuel Filter
Banjo Bolt............................................16
Service Bolt.........................................9
Clamp Bolt...........................................9
Valve cover Bolts...................................7
Spark Plugs..........................................13
Cam Gear Bolt.......................................27
Cam cover crown nuts.............................7
Crank(vibration) damper bolt...................119
Cylinder Head Studs....................1st step..22...2nd..49
Flywheel Bolts M/T................................76
Drive Plate bolts for A/T........................54
Header Bolts to Cylinder Head................22
Header to downpipe bolts.......................33
Intake Manifold Bolts..............................16
Oil Pan bolts...........................................9
Oil pick up tube bolts..............................17
Oil Pump to engine block bolts/nuts...........9
Oil Pump Screen bolts..............................8
Oil pump cover Screws.............................5
Oil filter Housing Bolts..............................9
Rocker arm shaft pedestal bolts................16
Rocker arm shaft end caps bolts................9
Timing belt adjstment bolt.........................31
Rod Bolts............................................. ....23
Main Bearings cap bolts
Separate caps and bridge..........................48
One piece cap assembly............................33
Water pump pulley bolts.............................9
Thersmostat housing bolts..........................9
Water pump attaching bolts.........................9
Fuel injection service bolts
88-90................................................ ......9
91up.............................................. ..........11
Throttle Body nuts.....................................16
Fuel Rail nut..............................................9
Manual Transmission
Countershaft locknuts................................65
End cover bolts.........................................9
Selector arm holder bolts...........................9
Tranny case to Flywhee housing..................20
Tranny to engine bolts
4 speed............................................. ........33
5 speed............................................. ........50
Clutch pressure plate bolts...........................19
Release fork bolts........................................22
Driveaxle/hub nuts.......................................134
Brake hose to caliper banjo bolts (front/Rear)...25
Master Cylinder Mounting nuts.......................11
Brake Booster mounting nuts.........................9
Modified by SOHCEK-Turbo at 2:37 AM 10/21/2006
SOHCEK-Turbo is offline   Reply With Quote
Old 03-05-2005, 12:54 PM   #2
EJ2-Fluffy's Avatar
Default Re: [FAQ] D Series Torque Specs for everyone (EKSOHCV-TechRider)
Nice
EJ2-Fluffy is offline   Reply With Quote
Old 03-05-2005, 01:04 PM   #3
Default Re: [FAQ] D Series Torque Specs for everyone (CRX-Fluffy)
excellent job. prime sticky material.
none of the old poopy is offline   Reply With Quote
Old 03-05-2005, 04:53 PM   #4
Default Re: [FAQ] D Series Torque Specs for everyone (All The New Rage)
Quote:
thanx
Old 03-05-2005, 09:10 PM   #5
Old 03-05-2005, 10:40 PM   #6
green91's Avatar
teh best rite up evar
green91 is offline   Reply With Quote
Old 03-05-2005, 10:54 PM   #7
Default Re: (green91)
I did something like this a while back for B series motors.
Just a little FYI 1 FT/LB equals 12 IN/LB, so if you want to use a beam type wrench which are almost all IN/LBS take your FT/LBS and multiply by twelve to get IN/LBS.
This is good to know because for any bolt requiring 20 ft/lbs or below, you should convert to in/lb because it's a little more accurate. Also when tightening bolts that you absolutely, positively do not want to break such as cam cap bolts whether its for B or D series, you should use a beam type torque wrench with IN/LBS and NOT a clicker type torque wrench which are usually FT/LBS.
BlueShadow is offline   Reply With Quote
Old 03-05-2005, 11:05 PM   #8
Default Re: (BlueShadow)
Cool were is your B series thread at you should post it on here. I would have added B series but I didnt have any books for them.
Old 03-05-2005, 11:10 PM   #9
Default Re: (EKSOHCV-TechRider)
Quote:
I did a FAQ thread similar to this, and I posted it in the EF forum. It is in page 2 of the FAQ thread at the top. I didn't include any engine/block internal TQ specs, cause I figure if you're doing any major internal work you'd want to have an FSM handy anyways.
Here is my thread, which I did a little different:
B SERIES COMMON TQ SPECS
Old 03-06-2005, 10:15 AM   #10
NICE
Old 03-19-2005, 06:50 PM   #11
up
Old 11-07-2005, 05:29 PM   #12
CrXThang's Avatar
Default Re: [FAQ] D Series Torque Specs for everyone (EK-TSOHCV-TaKRider)
Nice thanks for the info! I will need it soon
CrXThang is offline   Reply With Quote
Old 11-07-2005, 05:33 PM   #13
Coltmorris's Avatar
Default Re: [FAQ] D Series Torque Specs for everyone (CrXThang)
just what i was looking for!
Coltmorris is offline   Reply With Quote
Old 11-10-2005, 08:33 PM   #14
SECURITY's Avatar
Default Re: [FAQ] D Series Torque Specs for everyone (Coltmorris)
bump this
SECURITY is offline   Reply With Quote
Old 04-21-2006, 04:15 AM   #15
JDM RHD eg6's Avatar
JDM RHD eg6 is offline   Reply With Quote
Old 04-21-2006, 05:30 AM   #16
CRX Toad's Avatar
We all love you long time.
CRX Toad is offline   Reply With Quote
Old 04-26-2006, 01:55 AM   #17
snowking11's Avatar
nice post
snowking11 is offline   Reply With Quote
Old 06-13-2006, 12:37 PM   #18
torqueless's Avatar
Default Re: (snowking11)
where is the pressure plate tq specs?
torqueless is offline   Reply With Quote
Old 06-29-2006, 10:11 AM   #19
spuddo01's Avatar
Default Re: (torqueless)
needed this thanks
spuddo01 is offline   Reply With Quote
Old 03-12-2008, 09:53 AM   #20
leoaa777's Avatar
Default Re: [FAQ] D Series Torque Specs for everyone (SECURITY)
So..the headstud specs...u do it in any order? Any specific sequence or simply 1 full torque down at 22 lbs, then another run at 49?
leoaa777 is offline   Reply With Quote
Old 03-12-2008, 10:14 AM   #21
d0mm3y's Avatar
Default Re: [FAQ] D Series Torque Specs for everyone (leoaa777)
very nice post! thx
d0mm3y is offline   Reply With Quote
Old 03-19-2008, 06:01 PM   #22
eastbobdam's Avatar
Where are the ARP head studs spec? I see the 22, 49 in two steps. Is this for ARP or Stock?
Thanks.
eastbobdam is offline   Reply With Quote
Old 04-09-2008, 04:51 AM   #23
eastbobdam's Avatar
Default Re: (eastbobdam)
Anyone know?
One sticky from http://www.d-series.org/forums....html says the following
Cylinder Head Bolts for D16Y8
step 1(bolts 1-10)....15ft lbs
step 2(bolts 1-10)....36ft lbs
step 3(bolts 1-10)....49ft lbs
step 4(bolts 1 & 2)....49ft lbs
Cylinder Heads...All D ARP Studs
Step 1......15ft lbs
Step 2......30ft lbs
Step 3......62ft lbs
Old 01-28-2009, 09:57 AM   #24
Killerkov's Avatar
Wow guys ty so much for the info. I'm going to blot my tranny up tonight now that i have the right TQ for the flywheel bolts and PP, Thanks a bunch>Kov
Killerkov is offline   Reply With Quote
Old 05-22-2009, 03:29 PM   #25
you rock. thanks so much for all this usefull info. i wish everything were this easy
92EGminihatch is offline   Reply With Quote
How to build a "reliable" lsvtec/b20vtec bambam All Motor / Naturally Aspirated 2144 01-12-2017 04:58 PM
How to: Auto to 5spd Swap **lots of pics** s.cali alan Honda Accord (1990 - 2002) 154 12-26-2016 04:57 PM
How-To: 5th gen accord clutch install h22a2JZGTE Honda Accord (1990 - 2002) 21 05-26-2016 11:36 AM
FAQ B series torque specs BlueShadow Honda CRX / EF Civic (1988 - 1991) 54 09-17-2015 10:39 AM
What is the torque spec for the oil drain bolt???? Art Vandeleigh Honda Accord (1990 - 2002) 15 02-06-2002 12:27 PM
Tags
1990, 2006, 91, bolt, bolts, brake, civic, crx, head, honda, settings, si, spec, specifications, specs, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
