*searched* Speedometer Pulse?
Re: *searched* Speedometer Pulse? (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">How do our cable driven speedo's have a pulse?</TD></TR></TABLE>
The Speedometer in the dash does it. I've tapped off the wire before with success, but I'm trying to get the signal into LogWorks 2 as something usable, so I have to know the actual frequency.
There's info out there for people who have swapped s2000 clusters into their cars. They changed the pulse/mile (ppm) from their normal.
https://honda-tech.com/zero...ge=60
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Other info,
From what I can find the stock honda vss outputs 4000 pulses per mile (approximately)
and the s2000 vss outputs 145000 pulses per mile. That's a ratio of 36.25/1 A frequency multiplier that can create this 36.25/1 ratio is needed. I'm working on it, and if anyone else is, please post your info. I'd like to see some tuning involved, to adjust for the differences between individual vss gears. Shouldn't have to be too much, and speed doesn't have to be perfectly accurate (most stock speedos are about 5-7% off anyways.) </TD></TR></TABLE>
That info is for the tranny mounted vss's, however, I would assume the cluster mounted ones would be the same. Maybe take do your math with the 4000 ppm and see if it makes sense?
Good luck.
Good luck.
Mr. Giggles
08-11-2006 05:21 AM
speedracer33
28
07-23-2003 06:28 PM
