**the official ef suspension thread**
Old 03-27-2009, 06:21 PM
  #26
donaldmejr's Avatar
Default Re: **the official ef suspension thread**
JTC RGTC N1 Dampers
Da Front and Rear Brakes
Front Suspension-
Brembro Drilled slotted and vented rotors with axis brake pads
Stainless Steel Edelbrock Brake Lines
Revo front camber kit
Suspension Technique 23mm sway bar
Innovative Front Cross member
Rear Suspension-
Brembro Drilled and Slotted rotors with axis brake pads
Function7 88 CRX Rear LCA's
Wicked Tuning rear caster camber kit
Wicked Tuning rear toe camber kit
Energy Suspension rear control arm bushings
Wheels and tires
16 inch Rota C10s, in black
BFG KDW's Fronts are 225/45/16 and rears are 205/45/16
http://viewmorepics.myspace.com/inde...ageID=35312023
http://viewmorepics.myspace.com/inde...ageID=35446083
Old 03-27-2009, 06:41 PM
  #27
Maldito X's Avatar
I have Koni Yellows and Neuspeed Race Springs
Before....
After....
Old 03-27-2009, 06:53 PM
  #28
red_ef's Avatar
tein ss with pillowball uppermounts... thats about it
rear stance
front
Old 03-27-2009, 10:17 PM
  #29
trevorjohn88ef's Avatar
d2's all the way down in the back, about 1/16 in. left in the front. nice ride
Old 03-29-2009, 12:09 PM
  #30
hushypushy's Avatar
Ground Controls (shelf rates) on Tokico Illuminas set to 5 all around (stiffest). Front can go maybe an inch lower, rear maybe 1/8".
The ride is really nice, very smooth and the Illuminas dampen very well. Shelf rates are a nice DD spring for cruising, but they're a little soft, so carrying a full load of people tends to make the car super slammed (don't attempt to drive over stuff).
Previously I had it about an inch higher in the back and a little higher in the front with the shocks set to 4/3 F/R and damn, the ride was sooo nice, like OEM should be. Plenty of travel, great damping, etc. The only thing is, at the ride height I have it at now, it handles much better. I'm about -1º camber all around.
I know, those pics are super whored out, I need to take some new ones.
Old 03-31-2009, 04:33 PM
  #31
ricefighter's Avatar
Before....
After....
very clean CRX!!!
Old 04-09-2009, 08:56 AM
  #32
Track Advocate
BLU CIVIC's Avatar
90 Civic Si with D2 Coilovers and LCA's with 15x7 wheels...had them on for about 8 months...they're preloaded with the front all the way down and the rear i have about 3/4 more i can go down
can see how much room i have to lower in the rear (pic was taken when i was on 3 wheels going up my driveway)
Old 04-09-2009, 10:25 AM
  #33
liquor assassin's Avatar
skunk2 struts, i think the lca's are megan racing (not sure) and skunk2 coil over sleeves
i now have tokico illuminas but no pics of them yet
Old 04-09-2009, 10:38 AM
  #34
hondaownr's Avatar
S2 Pro-C's, S2 UCA's, Blox LCAS, ST Sway, Hf Front Sway, ebay strut kit
Old 05-03-2009, 05:17 PM
  #35
volksnuts's Avatar
anyone using function &form coilovers?
Old 05-03-2009, 05:44 PM
  #36
sde780's Avatar
No name coilovers, kyb GR-2 struts
Rides pretty good, I have it about halfway down
Old 05-03-2009, 10:19 PM
  #37
peasoupe's Avatar
JIC Magic eg coliovers
function 7 lca's
Benen tie bar
15" Ronal R8's
da swaybar bla bla bla
Old 05-04-2009, 12:09 AM
  #38
juan3023's Avatar
Before:
After:
tein circuit master type ra
Old 05-04-2009, 12:24 AM
  #39
88_acED6's Avatar
does anybody make extended top hats?
Old 05-04-2009, 12:47 AM
  #40
92civiceg9gsr's Avatar
^^^Ground-Control makes extended top hats^^^
Old 05-04-2009, 01:03 AM
  #41
exz0n-.-'s Avatar
anyone have ground controls?
im about to pick some up on wednesday, how are they?
and how low can you go on them?
Old 05-04-2009, 07:12 AM
  #42
SIkilla's Avatar
do you need new rear bushings if you are planning on using coilovers?
Old 05-04-2009, 07:54 AM
  #43
Track Advocate
BLU CIVIC's Avatar
not unless yours is currently messed up
Old 05-04-2009, 07:57 AM
  #44
Furyof4's Avatar
I'll play.
Ground control's w/ 450fr/500rr springs on tokico illuminas, homemade extended top hats front, hf front sway, st rear. No camber ajustment in the front, ingalls adjustable upper arms in the rear. A little tail happy for the street but works well on track(at my noobish level).
Old 05-04-2009, 08:59 AM
  #45
hushypushy's Avatar
Check the previous page with my car. Here's another pic:
I'm on Ground Controls (shelf rates) and Tokico Illuminas. The ride is fantastic. I haven't been but I imagine it's a little soft for Auto-X/track use but for daily driver business, this is awesome. My car handles phenomenally and the ride is stiff (compared to OEM), but I haven't yet had one person complain about it being too stiff, too bumpy, or anything. My girlfriend loves it! And I used to get all kinds of complaints when my EJ1 was slammed on stock shocks...
About the height--I'm pretty much all the way down. There is maybe a half inch lower to go in the rear, if that, and I'd say about an inch left in the front. So if you want to go super slammed, then this is not the setup to do it with. But if you want a good practical stance, ride, and excellent handling, I'd say go for it.
Old 05-04-2009, 10:29 AM
  #46
bryse68's Avatar
skunk2 rsx sleeve coilovers, ek front struts, s2000 rear struts
Old 05-04-2009, 12:38 PM
  #47
exz0n-.-'s Avatar
ah nice. yeah i personally want to go super slammed, but then again my gf drives my car a lot too so that would probably be a bad idea hahah. What size wheels and tires are you using? right now im rolling some 15's with 205/50/15s and they're rubbing the crap out of my fenders. need to roll them soon!
But yeah, im sure this is going to feel way better than riding around on blown struts in the rear with cut springs and no bump stops haha. such a terrible ride! Im getting the ground controls for 70$ plus it comes with stock struts that ill use for a bit until i can afford some decent ones.
ps: your car is super clean ^^ hope mine can be as clean some day.
Old 05-04-2009, 01:05 PM
  #48
EE2bitsk's Avatar
i got PIC selects. skunk2 front/rear camber kit as well.
all the way down in the back, about an inch left in the front.
Old 05-04-2009, 02:23 PM
  #49
88_acED6's Avatar
what are the ups and downs to extended tophats? what are the purpose for them?
Old 05-04-2009, 02:51 PM
  #50
661rex89si's Avatar
more shock travel duh hello. think about it bro
Quick Reply: **the official ef suspension thread**
