**the official ef suspension thread**
Old 10-21-2011, 10:18 AM
  #351
Touching My Member
.Manny.'s Avatar
Default Re: **the official ef suspension thread**
Originally Posted by hdsupercrewf150
I'd like to clarify if the DC/DB coilovers would work on the EF and what it takes for them to fit. Thanks.
You must use EG/DC front forks for the front and ITR/88 CRX rear LCAs if using ITR style Coilovers.
If you're going with standard DC/DB coilovers, just EG/DC front forks.
Old 10-21-2011, 11:44 AM
  #352
TearSDMF89dx's Avatar
im surprised 15 pages and only one person has progress....thats what im getting ...im running egay's that are frozen at stock height from last winter...i had to cut the struts off of the sleeves to change the rear struts last spring ...not to mention the springs are hella stiff and ride like sh*t
Old 10-21-2011, 05:31 PM
  #353
Jerms's Avatar
sprint springs and koni yellows
Old 10-22-2011, 05:54 PM
  #354
Ryan559's Avatar
Omni power full coilovers 12/10 set up, These are for an EG so they dont go as low as i would like so i couldnt get the stance i wanted. Also a lil rough on the roads but there great coilovers
Old 10-30-2011, 10:51 PM
  #355
EFyew's Avatar
just a scrub question but ... how do i go about getting the skunk2 extended top hats, and do they come in 2" for the front AND back?
Old 10-30-2011, 10:58 PM
  #356
EFyew's Avatar
stock struts, 50$ DNA Ebay Sleeves
Old 03-10-2012, 09:11 PM
  #357
eee ef'n's Avatar
looking to buy full coilovers for my 91 ef hatch, what suspension set up in my 600 dollar budget will be at least worth buying ?
Old 08-04-2015, 01:34 PM
  #358
Bigoc1655's Avatar
Originally Posted by mayniak
what size spacers did you use??
Koni yellows and GC is one of the top setups for yrs in autox amd still widely used now overall one of the best setup EVER! for the EF Chassis.
Old 08-04-2015, 03:15 PM
  #359
PHANTOM MENACE
24TEN's Avatar
You just quoted someone from beyond 4 years ago and didn't even answer their question. Please see the forum rules.
Old 10-12-2015, 08:57 PM
  #360
Binnsanity_ef's Avatar
Originally Posted by trevorjohn88ef
d2's all the way down in the back, about 1/16 in. left in the front. nice ride
Are those d2 springs or coilovers
Old 10-13-2015, 03:29 AM
  #361
MarksCivic's Avatar
Here's mine with Eibach Pro Kit springs and stock shocks. The tires are 205/50-15.
Old 10-14-2015, 02:45 AM
  #362
Freemananana's Avatar
I've got a set of GSR blades. I must say, I love them now. Ride height looks manageable too.
Old 11-06-2015, 01:10 AM
  #363
bigtimegambler's Avatar
Suspension:
- Progress CSII 10 kg/mm front and 10kg/mm rear
- Si front and rear sway bars (stock)
- OEM brand new upper control arms and outer tie rods
Alignment:
Camber - F -3.2 R -1.8
Toe F +1 (something off with geometry after installing the DA knuckles. Maxed out Tie rod threads. Need to cut thread to correct toe). R +0.2
Brake:
- DA brake booster and MC
- DA integra front knuckle assembly w/ disk
- 4040 prop valve
- DA rear trailing arms w/ disk (not installed yet because of broken bolt head in trailing arm)
Comments:
Measurements from center of wheel to bottom of fender are around 11.5" front and rear. Progress recommends a ride height of 11.5" to 12.5" so i am in spec. I am impressed with the overall quality of the progress coilovers. The 10k front and rear give the car a more oversteering nature. The stiff rear rate makes bumps very rough and highway ride choppy. Overall i would recommend them to anyone. Im tracking the car next year and this was a great start up suspension set up with customizable rates.
Front Suspension assembled. Progress coilovers reuse the OEM top hat and OEM forks. The kit comes with upgraded poly bushings for the top hat.
The tire is about flush with the fender. Excuse the horrible body work. Planning on doing the exterior this spring. This year was engine swap, suspension, and brake year.
Parked out on the street.
Old 11-06-2015, 05:29 AM
  #364
I actually find that my 500# rear springs aren't all that bad compared to other parts of my car. I'm not sure what 'highway speeds' are, but I regularly do 55-60 mph without any real decrease in comfort.
I had originally rated the 500# rear springs as harsher than they are because I was driving mainly through neighborhoods.
Old 11-06-2015, 12:36 PM
  #365
The harshness is all relative based on what roads you are driving on. My car is also gutted, so there is literally no weight over the 10k rear rate. The roads here in Calgary are terrible because of our winters. Lots of filled cracks, huge bumps, and most bridges are deformed. So this is my experience. On brand new roads my car rides quite nicely. but overall I am experiencing a very choppy ride. Because race car.
Old 11-06-2015, 12:46 PM
  #366
CRX God
whited's Avatar
I just quoted someone from 3 months ago and he didn't even ask a question.
Old 02-07-2016, 06:41 AM
  #367
bergercurtis's Avatar
Might as well use the official thread.. Anything new in the market for EF? I'm looking for a softer street setup. I'm slammed on Skunk2 coilovers from the previous owner, and they ride terribly. I want to keep close to stock height. Most searches bring back people looking for race coilovers or stiff sport. Even when 'street' is listed, it's vague. Looking for some insight.
Old 09-07-2022, 07:04 PM
  #368
Rob.'s Avatar
JUST LOWERED MY 1988 CIVIC SEDAN
lived dreams
07-09-2009 12:19 PM
alexEF
03-25-2009 08:36 AM
builtsinglecam
Suspension & Brakes
01-10-2009 07:17 AM
Mr.Death
12-18-2006 04:51 PM
Quick Reply: **the official ef suspension thread**
