Y8 to Z6 transmission swap - Honda-Tech
Old 05-15-2013, 03:57 PM   #1
Icon2 Y8 to Z6 transmission swap
I have a 95 Civic Ex coupe, with a D16Y8 (Automatic) right now. I want to swap the transmission with a Z6 manual transmission. I already have the transmission, a F1 stage 2 clutch kit, a clutch line, and a clutch pedal assembly kit.
I was wondering what other parts would I need to make the swap?
What complications can be expected when doing the swap?
Also what is a reasonable price from a mechanic to do the swap, and how long would it take to complete it?
CaliGrown1994 is offline   Reply With Quote
Old 05-15-2013, 05:15 PM   #2
aavtec's Avatar
Default Re: Y8 to Z6 transmission swap
D16Y8 in a 95 civic, did someone do a motor swap? As for the conversion, you will need both clutch cylinders (master,slave), a manual transmission mount (may need modification), passenger and maybe drivers side cv joint, shift assembly, and if you clutch kit didn't come with a fly wheel you will need that as well.
aavtec is offline   Reply With Quote
Old 05-15-2013, 07:22 PM   #3
I was told the flywheel and transmission mount would not need to be changed and the Y8 and Z6 axles are the same, do you think that information is wrong? I have the clutch cylinders and shift assembly.
Old 05-15-2013, 07:26 PM   #4
The auto axels are different and so is the flywheel at least on an auto Z6.
Megaton22 is offline   Reply With Quote
Old 05-15-2013, 08:03 PM   #5
tlarimer's Avatar
Quote:
That is completely false about the AT and MT axles being different
44010-SR1-013 R
44011-SR1-013 L
Only difference would be if it was ABS and the only difference there is the ABS ring on the outer knuckle.
AT do not have flywheel's, they have a driveplate, so no you will not be able to reuse it. Also you will need to get different bolts to mount the flywheel, since AT bolts are shorter, plus pressure plate to flywheel mounting bolts.
tlarimer is offline   Reply With Quote
Old 05-15-2013, 08:10 PM   #6
I stand corrected. The abs ring is the difference I noticed between the axels that came out of the auto ex I got my engine from and my dx axels. Didnt realize the difference was because of abs.
Old 05-15-2013, 08:17 PM   #7
tlarimer's Avatar
^Not trying to bust your *****, just trying to clear up some of the misinformation.
OP, you need to check the FAQ sticky at the top of this forum.
Also check this link:
92-95 Civic auto to manual parts list
Old 05-15-2013, 08:20 PM   #8
No offense taken, I appreciate it in fact. I certainly dont want to spread bad info. Typically I dont post on threads like this because I am still learning myself but since I just did this swap and there was a difference in the axels I thought I would post. I just assumed the difference was because of the auto tranny and didnt think about the abs.
Civic ef d16y8 swap SenseiRice Hybrid / Engine Swaps 2 04-23-2016 03:23 AM
My transmission went out Zero14zz Acura Integra 6 09-23-2015 04:54 AM
Cable to hydraulic conversion D16Z6 EFchesYO Honda CRX / EF Civic (1988 - 1991) 7 09-21-2015 04:18 PM
WTB: EK 5-speed swap parts/y8 camshaft & Valve Cover eksands Want to Buy 12 04-21-2011 08:01 AM
d15b7 swap to d16z6 dippy Honda Civic / Del Sol (1992 - 2000) 27 02-27-2009 06:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
