y7 surges when driving
Old 07-27-2013, 04:08 AM
brent_si's Avatar
Default y7 surges when driving
I just Bought a beater/daily driver. Its a 98 civic dx and it is not throwing any codes(at least not yet). When driving it starts to bog down then it will surge back up and bog down again. When it bogs it looses all power like it wants to die. The good thing is the seller told me of the issue and I got a good deal.
It does not do this all the time. In about 60 miles it has done it 2 times both times only lasting about 5-10 seconds. So far I have only cleaned off the maf sensor. Any suggestions on what to check first would be helpful.
Thanks,
Brent
Old 07-27-2013, 04:31 AM
CO671's Avatar
Default Re: y7 surges when driving
also: there's no MAF sensor, it's MAP that's on the throttlebody
check the distributor rotor/cap? fuel filter clogged?
I noticed you said while driving and not at idle... but if it's at idle too check some of these links:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Old 07-27-2013, 04:44 AM
brent_si's Avatar
Its so intermittent that i have not noticed it at idle. It bogs down like its out of gas I have never had this issue with a normal surge. I would think if the filter were clogged that it would be more consistant. I suppose I will check both of those out just in case.
Old 07-27-2013, 12:06 PM
B_Swapped93's Avatar
i'm willing to bet worn cap+rotor my GS-R did something similar that was the case take the cap off and inspect.
Old 07-27-2013, 12:14 PM
VeganEJ8's Avatar
Check your fuses...
tstevens3754
11-18-2012 09:39 PM
brant
03-29-2011 06:43 PM
greenzchatch
07-29-2010 02:14 PM
Circaskaterr
01-26-2010 08:09 PM
TORQUE MONSTER
08-22-2002 04:03 AM
Quick Reply: y7 surges when driving
