Wiper Motor Wiring Question
Old 01-11-2013, 12:19 PM
slimjim07's Avatar
Default Wiper Motor Wiring Question
I need help asap! I bought a 97 civic ex that was built and wire tucked. Problem is my windshield wipers wont come on. I took everything apart and there was no wire harness going into the wiper motor. If somebody could help me in any way find out where the wires could be or a diagram so I could wire a new harness in that would be very helpful thank you.
Old 01-11-2013, 12:48 PM
Former User's Avatar
Default Re: Wiper Motor Wiring Question
The diagram below shows the shape of the wiper motor connector:
Old 01-11-2013, 12:58 PM
slimjim07's Avatar
I cut one of those off another civic at the junk yard but I have no idea what to wire it to
Old 01-11-2013, 01:02 PM
The diagram below shows the wire colors that pin to each numbered connector position for the motor.
Old 01-11-2013, 01:43 PM
slimjim07's Avatar
I feel like an idiot but could you help me understand that diagram a little bit better
Old 01-11-2013, 07:09 PM
In the diagram in post #4, there's a box labeled windshield wiper motor. From the box extends lines (wires) labeled 1, 2, 3, 4, or 5. If you follow each numbered line, it is labeled with a wire color. For example, 1 leads to Blu/Yel. The numbers around the box are the same as those in the connector circled in the diagram of post #2. From this, you know the wire color that pins to each of the five positions of the motor connector.
Old 01-11-2013, 07:24 PM
slimjim07's Avatar
I know the color of the wires but I don't see those colors to hook them up to in my fender well or under the dash
Old 01-11-2013, 07:32 PM
A zoomed out view of the circuit diagram may help. For example, you can tell that the Grn/Blk power wire at pin #4 of the motor connector comes from 20A fuse 26 of the dash fuse box. And the Blu/Wht wire at pin #5 of the motor connector comes from integrated control unit plugged into the rear of the dash fuse box. Etc.
Old 01-11-2013, 07:42 PM
slimjim07's Avatar
That does help thank you. So all the wires aren't gonna be going through the firewall in the fender?
Old 01-11-2013, 07:55 PM
These diagrams should help. The motor connector (C301) is on the left branch of the main wire harness. Its wires run to the dash fuse box, integrated control unit, wiper switch, or G401.
Old 01-11-2013, 08:09 PM
slimjim07's Avatar
That's confusing as hell but I think I can figure it out with the other diagram you posted hopefully
Old 01-11-2013, 08:13 PM
Who said it would be simple...haha?
The diagrams in my last post appear to show that the wire harness for the wiper motor drops down from the cowl area, merges with the main wire harness, and then passes through the firewall to behind the dash, where the wiper motor wires branch to the various locations I mentioned.
If you get stumped, just post specific questions.
Old 01-11-2013, 08:22 PM
slimjim07's Avatar
Haha very true and yeah I see all that thanks for all the help I'm gonna try to get it working tomorrow and will keep you posted.
Old 01-11-2013, 10:27 PM
Oh look, I can change this
deschlong's Avatar
Yikes, talk about trial by fire!
Old 01-12-2013, 07:04 AM
slimjim07's Avatar
Why you say that lol
Old 01-12-2013, 07:08 AM
slimjim07's Avatar
All I need to know is where the number 1 and 2 wires go the blue/yellow and the blue?
Old 01-12-2013, 07:12 AM
Both go to the wiper switch on the steering column -- pin 1 (Blu wire) and pin 2 (Blu/Yel wire) in the 8-pin switch connector:
Old 01-12-2013, 07:20 AM
slimjim07's Avatar
In the diagram you posted 1 is blu/yel not blu?
Old 01-12-2013, 07:23 AM
slimjim07's Avatar
Nevermind that last post I get what you meant now
Old 01-12-2013, 09:33 AM
slimjim07's Avatar
I got everything hooked up except I can't find the green/black one on the fuse box
Old 01-12-2013, 09:52 AM
slimjim07's Avatar
I found it thanks for all the help man I really appreciate it!
SuperSlowEF8
08-16-2011 06:30 AM
Mark Murda
06-07-2011 07:24 PM
ninjarico
06-23-2009 07:02 AM
Geone
04-22-2004 03:16 PM
roydogg
09-07-2003 10:26 PM
Quick Reply: Wiper Motor Wiring Question
