windshield wipers won't work - blown fuse - Honda-Tech
Old 09-19-2011, 08:20 PM   #1
Default windshield wipers won't work - blown fuse
Hi. I tried to turn on my windshield wipers but they wouldn't work. I check the fused, it was burned out. Replaced it and I tried to turn the wipers on and it worked but I tried again and they won't work. So is it the motor or something else?
2000 Honda Civic.
Rach25 is offline   Reply With Quote
Old 09-19-2011, 08:35 PM   #2
Just Another Mod on H-T
EsotericImage's Avatar
Default Re: windshield wipers
did the fuse blow again?
EsotericImage is offline   Reply With Quote
Old 09-19-2011, 08:39 PM   #3
virgineg6's Avatar
x2
virgineg6 is offline   Reply With Quote
Old 09-20-2011, 07:46 AM   #4
Default Re: windshield wipers won't work - blown fuse
yes the fuse did blow again.
Old 09-20-2011, 08:02 AM   #5
virgineg6's Avatar
Check your wiring might have a break or a tear somewhere thats grounding out causing the fuse to blow
Old 09-20-2011, 08:45 AM   #6
Two Piece
Go_Race_Your_Self's Avatar
Quote:
x2
When you got a short that grounds before the consumer it will blow the fuse since the consumer didnt use the power.
Kev
Go_Race_Your_Self is offline   Reply With Quote
Old 09-20-2011, 02:08 PM   #7
I am not a car person. Where can I find the wires to see if they broke or have a tear in it?
Old 09-20-2011, 05:08 PM   #8
Does unplugging the windshield wiper motor prevent the fuse from blowing?
Former User is offline   Reply With Quote
Old 09-20-2011, 08:39 PM   #9
Quote:
Where is the motor? I am not a car person.
Old 09-20-2011, 08:57 PM   #10
Does the fuse blow only when the wipers are turn on? If so, does the fuse blow when the wipers are set to low or high?
Do you have a multimeter?
Old 10-07-2011, 01:51 PM   #11
Hi again. I took my car to a car shop and they said it shorts out when I do the wipers for the wiper fluid. He got it working temporaily but he says he wants it for a full day. What does that mean? Could it be the motor or the wiring? I just want to know.
Old 10-07-2011, 01:54 PM   #12
The Grumpiest
grumblemarc's Avatar
What does that mean "he wants it for a full day"? You should have asked HIM that question. Did you ask him what he was going to be doing for the day he wants to keep it? How much is this going to cost you? All questions you should have asked him, not us.
grumblemarc is offline   Reply With Quote
Old 11-27-2012, 01:28 PM   #13
Icon2 Re: windshield wipers won't work - blown fuse
I'm having the same problem with my windshield wipers. Did anyone resolve the issue and know the answer to why this happens?
Sheena Vera is offline   Reply With Quote
Old 06-15-2013, 09:49 PM   #14
I had same problem and found a short near the firewall where the wiper motors wires come through into the engine area. The wires are wrapped in plastic flex hose before and after the firewall. Through the firewall they aren't wrapped and one of the wires insulation was worn through with the copper wire exposed. This looks like a poor way to route cables - should be wrapped here as well. Hope this helps someone isolate their problem.
Dadmechanic is offline   Reply With Quote
Old 10-05-2015, 11:24 AM   #15
Hello, I have the same problem, but at the same time light on the "brake lamp light", any one have the color code or diagram?
Lop1 is offline   Reply With Quote
Old 10-05-2015, 11:24 AM   #16
I have the same problem, anyone have the harness diagram or wire color code?
Windshield wipers stop when lever released / wont park Dev1996 Honda Accord (1990 - 2002) 5 08-11-2016 03:38 PM
2007 CRV Rear Wiper Motor Woes JimmyAtlantis Honda Element & CR-V 4 12-06-2015 06:03 AM
windshield wiper dont work when using nozzle richard203 Honda Civic / Del Sol (1992 - 2000) 5 07-26-2015 07:01 PM
One wiper won't move Sadus Honda Accord (1990 - 2002) 2 05-19-2007 11:30 AM
Wiper Motor issues - please read swtch7 Honda Civic / Del Sol (1992 - 2000) 5 03-02-2006 01:01 PM
Tags
2000, 93, blown, civic, fuse, fusible, honda, move, prelude, windshield, windshild, wiper, wipers, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
