Window will go down but it wont stop, then it wont go back up! help
95 civic ex
When i roll down my drivers side window it automaticly goes all the way down, but then it wont stop and it will still make the noise like its going down. So i tap the power window up and it quits.
When i try to roll up my window it will go up a couple inches, then it stops. If i pull (really hard) up on the window while rolling it up it will go back up.
So whats the problem? Its not like its popping out of track or anything. Its like the motor is messed, but it still works.
Help thanks!
Help thanks!
Re: Window will go down but it wont stop, then it wont go back up! help (EGcivicBoy)
it might be the computer malfunction or the crank gear on that window is slipping....
EDIT: or if the motor's still working...and it goes up by force...it should be the mislocation of the window. try opening up and see.
Re: Window will go down but it wont stop, then it wont go back up! help (handa)
anyone else have an idea?
The window will go up couple inches. And if i just crack the window it will roll up no problem... hmmm
Sounds like the window is off track. Fairly easy fix, just can be a pain in the ***.
Newhondawhothis
02-19-2018 03:46 PM
hondaEg_808
11-30-2010 12:35 AM
