will motor mount inserts eliminate idle vibration?
My transmission vibrates at idle and whole car vibrates so bad when i turn on AC. It's old motor mount. car has 110k miles on it. But i dont want to spend couple hundreds dollars on mounts. So i am planning to get Energy Suspension Motor Mounts Inserts. Will this insert will help the vibration or make it worse? If it'll make it worse, any other suggestion other than getting new mounts? thanks
Solbros Owns Me
Re: will motor mount inserts eliminate idle vibration? (bearboy80)
it will be worse. The inserts will cause the engine to not "torque" or move as much inside the engine bay, transferring that enegery to the car or to the wheels instead.
I would get a new mount if you want the smoothest feel
Re: will motor mount inserts eliminate idle vibration? (Emerika)
Same problem here.
It got worse.
Well...actually...the vibration didn't get any worse, it just got more noticeable inside the car.
It got worse.
andyep3
11-10-2008 06:21 AM
dema12co
12
05-08-2006 11:21 AM
TypeRuz
02-07-2004 10:04 PM
yusoslo
01-28-2004 07:22 PM
