Will Hmotors swap shift linkages when purchasing an engine?
Old 07-02-2005, 07:11 PM
Bryro22's Avatar
Default Will Hmotors swap shift linkages when purchasing an engine?
I am purchasing a GSR complete swap from hmotors on Tuesday and wont be able to get ahold of them until then (closed on 4th of July). I just wanted to know from any of you that have dealt with hmotors, will they be able to give me a Del Sol VTEC shift linkage instead of the GSR shift linkage that comes with the swap?
One more question:
Will the stock GSR motor mounts that come with the complete swap from hmotors work with the Del Sol or do i need to purchase different ones?
Thanks!
Old 07-02-2005, 07:26 PM
Luserkid's Avatar
Default Re: Will Hmotors swap shift linkages when purchasing an engine? (Bryro22)
Theyll work but the bitch, and both front torque rubber mounts need to be your civic/del sol ones.
Old 07-02-2005, 07:35 PM
Bryro22's Avatar
Default Re: Will Hmotors swap shift linkages when purchasing an engine? (Luserkid)
uuhh..dont know that i understood your reply
Can anyone give a clear answer to my questions???
Thanks!
Old 07-02-2005, 07:58 PM
komat's Avatar
if they dont
just ask steve to work something out with you
hes a reasonable man if u are nice to him
the motor mounts will work
they dont give u the torque mounts you will need to reuse yours from your civic/delsol
Old 07-02-2005, 08:00 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryro22 &raquo;</TD></TR><TR><TD CLASS="quote">uuhh..dont know that i understood your reply
Thanks!
You will when you pull your motor.
Bryro22's Avatar
Default Re: Will Hmotors swap shift linkages when purchasing an engine? (komat)
what about the GSR motor mounts, are those the ones i need to make the motor fit in the Del Sol?
Old 07-02-2005, 08:03 PM
komat's Avatar
you need to research more b4 u do your swap.....
the mounts that come with the gsr will work
Old 07-02-2005, 08:07 PM
Bryro22's Avatar
Sorry Komat I didnt see that you already said the mounts will work.
Thanks for the info...I will search more before posting.
Old 07-02-2005, 08:09 PM
Will_the_Thrill's Avatar
do u have a del sol vtec? if so, then (from what i understand, its a b16 and b series parts, for the most part, can be interchangeable from what i heard ) the mounts should work.
EDIT: ^ beat me to it
mish__
03-18-2011 05:13 PM
Nj_Sol PWR
12
03-02-2009 02:43 PM
NZDelsoldude
02-15-2009 01:58 AM
purpleandgreen
03-04-2008 10:33 AM
90civichb
06-05-2004 04:13 AM
Quick Reply: Will Hmotors swap shift linkages when purchasing an engine?
