will a d16y7 tps sensor work on a y8?
Old 05-03-2007, 09:54 AM
JLEK's Avatar
Default will a d16y7 tps sensor work on a y8?
will a d16y7 tps sensor work on a y8? if so after swapping what should i look for?
thanks,
j
JLEK is offline
Old 05-03-2007, 11:10 AM
Slurp56's Avatar
Default Re: will a d16y7 tps sensor work on a y8? (JLEK)
Yes, they are pretty much ALL interchangeable. You'll need to use a volt meter to calibrate it though. about 0.5V at closed throttle and about 4.5V at WOT.
Slurp56 is offline
Old 05-03-2007, 11:11 AM
DaX
DaX's Avatar
Default Re: will a d16y7 tps sensor work on a y8? (Slurp56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slurp56 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, they are pretty much ALL interchangeable. You'll need to use a volt meter to calibrate it though. about 0.5V at closed throttle and about 4.5V at WOT.</TD></TR></TABLE>
I set mine at 0.45V @ closed throttle, but fair enough.
Just don't use a TPS from a DPI manifold.
DaX is offline
Old 05-20-2015, 10:58 AM
francis_the_civ's Avatar
How do you calibrate it?
francis_the_civ is offline
Old 05-20-2015, 11:04 AM
Former User's Avatar
The answer is in post #2. Please create your own thread if you're still confused.
Former User is offline
KiNGDEE206
04-01-2014 11:34 AM
sasinorm01
05-21-2012 04:48 AM
alupso
Southeast (Sales)
10-11-2008 05:54 PM
hkboy87
07-10-2007 07:52 PM
gator88
14
12-22-2006 11:01 AM
Quick Reply: will a d16y7 tps sensor work on a y8?
