will bad struts cause camber?
Re: will bad struts cause camber? (shizkabob3421)
I think they should effect camber since the shocks will drop more and it means to get alignment.
Re: will bad struts cause camber? (Dickies_n_FlipFlops)
well i have a camber kit already and i wanted to know cause im getting an alighnment tommrow..and i have bad struts i was wondering if that would affect it even after i got an alighnment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shizkabob3421 »</TD></TR><TR><TD CLASS="quote">like the tittle says will bad struts make your car camber worse..or is it all about the alignment?
thanks.</TD></TR></TABLE>
not really, atleast it hasn't happen to my wifes saturn. she blew the strut and has been driving like that for over a year, along with no alignment for over a year and the tires are good, no signs of premature wear.
The springs/coilovers are much more likely to screw up the ride height and therefore camber.
A blown shock just removes the dampening and added resistance to shock, the spring is where most of the weight is carried on. An old bent/sagging/cut spring may cause this, but a blown strut will likely have a minimal effect on your camber.
Re: (tazeat)
ok i have neuspeed springs like 2.5 in drop on stock struts it was like that when i bought the car and im 17 and no job so i have no money to replace struts..and it is just eating tires all my friends have been donating steelies to me forever and now i have enough money for a alighnment so i hope that helps with it.
Re: (shizkabob3421)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shizkabob3421 »</TD></TR><TR><TD CLASS="quote">ok i have neuspeed springs like 2.5 in drop on stock struts it was like that when i bought the car and im 17 and no job so i have no money to replace struts..and it is just eating tires all my friends have been donating steelies to me forever and now i have enough money for a alighnment so i hope that helps with it.</TD></TR></TABLE>
most likely the whole time you had a bad alignment. get the alignment then find a way to save up for some struts. mow some yards if you need to!
Re: (philosofy1)
ok thanks alot for the help..ahha yea ive been stripping like copper wire..for money cause we just rewired our house i got some cash for axles a few mounths ago..now i should have enough for an alighnment!
da9pwnsu
09-26-2005 05:21 AM
