Will a bad heater core cause the engine to overheat? - Honda-Tech
Old 04-27-2004, 02:45 PM   #1
NatedoggAZ's Avatar
Default Will a bad heater core cause the engine to overheat?
curious about this one....
may have been the cause of my old engines problems...want to be sure that same problem does not persist with my new swap...
thx!
NatedoggAZ is offline   Reply With Quote
Old 04-27-2004, 02:58 PM   #2
lsvtecracer's Avatar
Default Re: Will a bad heater core cause the engine to overheat? (NatedoggAZ)
If the heater core is leaking then yes it will cause the car to overheat because the cooling system will slowly lose all the coolant. You can bypass the heater core, but you won't have heat in the winter time. It's a temporary fix if you don't have the time or money to fix it.
lsvtecracer is offline   Reply With Quote
Old 04-27-2004, 03:00 PM   #3
NatedoggAZ's Avatar
gotcha, where will the coolent be leaking - on the inside or outside?
Also, I do live in Arizona and we rarely use our heatrers here...
maybe I should just bypass it for now if it turns out to be the problem - is that a pain in the ***?
Old 04-27-2004, 03:23 PM   #4
Race Egr's Avatar
If its leaking you will smell antifreeze inside ur car. It's a major pain to replace to, you have to pull the whole dash out. Just bypass it if you dont use your heat.
Race Egr is offline   Reply With Quote
Old 06-25-2014, 06:15 AM   #5
I did a heater core bypass cause the collant was leaking into my carpet and the car would over heat but it still seems to over heat does anyone know why??
Dc4cris is offline   Reply With Quote
Old 06-25-2014, 06:30 AM   #6
I never narc'd on nobody!
NotARaCist's Avatar
Well for starters, don't bump a 10 year old thread. Ever. Just don't do it.
The overheating obviously wasn't being caused by your heater core. You have a leak somewhere else. Start finding it.
NotARaCist is offline   Reply With Quote
Fan problem? spens 91 Ef Honda CRX / EF Civic (1988 - 1991) 11 04-14-2009 06:59 PM
headlight warning thingy winkwitstyle Lighting 3 01-19-2008 01:57 PM
could a bad starter cause problems? AznBlueBoy Honda Prelude 7 05-25-2004 02:48 PM
Will stock exhaust harm engine? fire7882 Honda Civic / Del Sol (1992 - 2000) 2 12-05-2002 11:18 AM
Ignition system recall on 1998 models & engine rebuilds? htludernewbie Honda Prelude 2 08-24-2002 09:45 PM
Tags
1990, 1992, 94, accord, bad, bypass, bypassing, car, civic, core, engine, heater, honda, leaky, overheat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
