car wont start
Old 04-28-2010, 11:44 AM
obuhmyuh's Avatar
Default car wont start
jdm d15b (eg) wont start, crank, nothin.fuel pump primes, CEL comes on and turns back off, changed out the starter, fuses look good, grounds look o.k., and tried jumping. Bump starting down a hill worked... any ideas?
Thanks in advance
Old 04-28-2010, 01:40 PM
tunedbylorange.com's Avatar
Default Re: car wont start
have you checked for spark yet?
Old 04-28-2010, 01:44 PM
Former User's Avatar
1) Check the safety starter switch at the top of clutch pedal. Could be a bad switch or the rubber stopper broke or fell out.
2) Check whether the starter cranks if it is wired directly to the battery.
3) Check the ignition switch.
Old 04-30-2010, 02:19 PM
obuhmyuh's Avatar
car wont even turn to test for spark, ill check that clutch bypass under where my left foot is, that's been the culprit before.
Old 04-30-2010, 02:33 PM
obuhmyuh's Avatar
checked the clutch switch, ill try wiring the starter to the batt. when i get off work tonight... and maybe take a closer look at the fuses by my left knee...
weird thing i noticed... the fuel pump runs (or the fuel system is doin somethin) when i turn the key to the cranking position (III) and hold it there...
Old 05-02-2010, 02:55 PM
obuhmyuh's Avatar
wired starter up and nothin still, beat on it, nothin... switched out the ecu with one that ive used before (think it still works), but it did the same thing. turn the key everything's normal fuel pump primes, shuts off, CEL comes on and off (stays off), when i try to turn the motor all I hear is the fuel system priming.
Old 05-03-2010, 09:19 AM
obuhmyuh's Avatar
bump
Old 05-03-2010, 10:21 AM
If, when wired directly to the battery, the starter won't crank the engine, then the engine is seized or the starter is bad. I assume that because the fuel pump primes, the transmission ground is fine.
Old 05-04-2010, 11:55 AM
obuhmyuh's Avatar
i doubt the engine is seized because i am able to bump-start it, or at least that's how i got it home... I'm on the same page about the starter, just weird that my spare is bad (guess that's why it was just lyin around, huh?)
Old 05-04-2010, 12:48 PM
honda_luvr_2000's Avatar
Yep, sounds like starter for sure. If the spare starter was well used before left sitting it's possible that the contacts inside corroded, or that the brushes for the starter failed, or even that the hold down solenoid in the starter took a dump.
Old 05-04-2010, 02:15 PM
seifertjoey's Avatar
check the ecu my buddys car did the same thing with the same motor just the other day,we changed the ecu and it fired right up and runs great with the p28 in it now
stl eh2
12-03-2009 10:07 AM
eaz_e
22
06-23-2009 02:39 PM
lilsol89
07-15-2008 07:40 AM
rodvang
23
11-05-2005 05:57 PM
scrap1ngsr
03-04-2003 11:59 AM
Quick Reply: car wont start
