wife kicked fuse panel in her 98 civic now 3 codes. p0500 p0135 p0141
Old 12-20-2007, 04:22 PM
Grncivic98...'s Avatar
Default wife kicked fuse panel in her 98 civic now 3 codes. p0500 p0135 p0141
after a quick look i found no visible damage. no damaged fuses. is the electrical load detector in the fuse panel inside the car? is there a chance that it was damaged by here kicking it? please give me any input you have this is her daily driver and i need to get it going
thanks
Old 12-20-2007, 04:40 PM
z6hatchboy's Avatar
Looks like you used a code reader. You could just look up the first few posts of this forum, and see how to check the codes for yourself and see what they mean, then go from there.
Old 12-20-2007, 04:51 PM
Default Re: (z6hatchboy)
actually i used my snap-on scanner, i know what the codes mean but i'd like to know the connection between them
Old 12-20-2007, 05:30 PM
z6hatchboy's Avatar
I dont know how the two are connected, but was there something that could've happened while she was driving that could contribute to the codes and her kicking the panel?
Old 12-20-2007, 05:49 PM
no dude she was getting in the car and slipped. When she started the car the mil light came on and the head lights began flashing dim. read a bunch of stuff on various sites about an "electrical load detector" located in a fuse panel. seems to me that if it does like it sounds it would control the voltage regulator in the alternator which lead me to believe this could be the problem
Old 12-20-2007, 05:52 PM
z6hatchboy's Avatar
Oh, guess i mis-read what you said earlier. What you've said on the electrical load detector sounds like the right track though.
Old 12-20-2007, 06:01 PM
hplssone's Avatar
Default Re: wife kicked fuse panel in her 98 civic now 3 codes. p0500 p0135 p0141 (Grncivic98...)
IF YOU HAVE THE RADIO CODE I WOULD TRY RESETING THE COMPUTER AND SEE IF THE CODES COME BACK THEY MIGHT BE GHOST CODES
Old 12-20-2007, 06:13 PM
Default Re: wife kicked fuse panel in her 98 civic now 3 codes. p0500 p0135 p0141 (hplssone)
ya i tried, came back right away.
Old 12-20-2007, 07:19 PM
jdmracer12's Avatar
the load detector is located in the fuse panel under the hood.
Old 12-20-2007, 07:53 PM
Dramier's Avatar
Actually, I don't think your problem here has anything to do with the fusebox, but it's still possible.
Start at the intake manifold bracket. Directly underneath the intake manifold bracket you will find connector C115. Inspect that connector for damaged wires, and replace or repair any damages you find.
Also check Fuse 15 to make sure it's not blown.
Reply back here with what you find or don't find and we'll go from there.
Old 12-21-2007, 07:10 PM
Default Re: wife kicked fuse panel in her 98 civic now 3 codes. p0500 p0135 p0141 (Dramier)
thanks guys, there was a wire shorted to the bracket on the under side of that connector. fixed the wire, replaced the fuse, cleared the codes and were off and running again......
Thanks alot for your help
Old 12-21-2007, 07:23 PM
z6hatchboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dramier &raquo;</TD></TR><TR><TD CLASS="quote">Actually, I don't think your problem here has anything to do with the fusebox, but it's still possible.
All i can say is, your good .
greeen ranger
06-16-2013 06:38 PM
Cdeese910
10-25-2012 07:56 AM
EJ8 GSR-T
10-23-2004 02:06 PM
crazyimport
07-19-2004 12:43 PM
Quick Reply: wife kicked fuse panel in her 98 civic now 3 codes. p0500 p0135 p0141
