Wierd loud clicking noise from front left wheel well?!?!
Old 07-21-2003, 02:43 AM
BoostedSixthGen's Avatar
Default Wierd loud clicking noise from front left wheel well?!?!
i was driving home about a week ago from a friends house and started to notice this wierd tickin noise from the front left tire/wheel well area....didnt really think much about it.....thought mabye it was just alignment or something but since then it has gotten a lot louder and i have no idea wat it is. It also only happens when i let off the gas or brake....when im pushing on the gas or the brake it doesnt make the noise. Im guessing it might be something with my axel or something i really have no idea. thought mabye someone would know wat this is if this has happened to them before or something. o ya, my car is 99 EK coupe with b18c motor.
Old 07-21-2003, 02:54 AM
civictypenos's Avatar
Default Re: Wierd loud clicking noise from front left wheel well?!?! (Honda GSR)
make sure your lugs are tight,ihad that same noise,it was a loose lug nuts,while accelerating it would go away,but as i slowed down the wheel would start hitting the studs and making a thud thud noiseevery so many feet till i stopped.
Old 07-21-2003, 02:55 AM
beeboyee's Avatar
sounds like axle problems
check that quick!
Old 07-21-2003, 03:25 AM
Mar_DC2's Avatar
i had a similar problem, at first i thought it was only the drivers side wheel well because thats the only place i could hear it from inside the car, but it turned out to be coming from the tranny. have someone listen from outside your car and if they say its coming from all around its probably something in the tranny. here's the link to my thread about the same thing:
https://honda-tech.com/zerothread?id=565085
ive concluded that its my clutch, but im going to have it checked out to be sure.
Old 07-21-2003, 04:42 PM
Chillin94hatch's Avatar
Default Re: Wierd loud clicking noise from front left wheel well?!?! (Btown_99Si)
i hear the same noise in my eg...people are telling me it could me bad cv joints?
Old 07-21-2003, 04:45 PM
CycoVizion's Avatar
Default Re: Wierd loud clicking noise from front left wheel well?!?! (Chillin94hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillin94hatch &raquo;</TD></TR><TR><TD CLASS="quote">i hear the same noise in my eg...people are telling me it could me bad cv joints? </TD></TR></TABLE>
yea, it usually is.
Old 07-21-2003, 05:15 PM
xJ.SLOTHx's Avatar
sound like a CV boot problem...
Old 07-21-2003, 05:18 PM
allmtr's Avatar
Default Re: Wierd loud clicking noise from front left wheel well?!?! (ian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian &raquo;</TD></TR><TR><TD CLASS="quote">sound like a CV boot problem...</TD></TR></TABLE>
Old 07-21-2003, 05:20 PM
Heinz57's Avatar
Default Re: Wierd loud clicking noise from front left wheel well?!?! (allmtr: now at 95%)
isn't it the cv boots when it clicks when one turns in the car? or can it also be when driving straight?
Old 07-21-2003, 05:34 PM
One2Three's Avatar
Default Re: Wierd loud clicking noise from front left wheel well?!?! (Heinz57)
I experienced the same tickling noise and it turned out to be my tires ripping apart....so you might want to check that out.
Old 07-22-2003, 01:49 AM
Default Re: Wierd loud clicking noise from front left wheel well?!?! (One2Three)
haha the noobest thing i've ever done............lug nuts were not tightened down all the way and were unscrewing themselves
Old 07-22-2003, 04:55 AM
ha,i should get a damn cookie or something!!!!!!!!!!!!!!!!
Old 07-22-2003, 05:20 AM
SiFan's Avatar
Get ready to dump some cash in her. sounds like your cv boots gone and the cv joint is grinding. If she's lowerd you mite go with axels better than factory.www.tciauto.com or the axel shop .com (i think?). If you swaped motors sometimes the shafts arnet long enough and will pull the boot apart. If its lowerd sometimes it puts undo stress on the axels and wears then out quick!
Old 07-22-2003, 05:31 AM
splitime's Avatar
Default Re: (SiFan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiFan &raquo;</TD></TR><TR><TD CLASS="quote">Get ready to dump some cash in her. sounds like your cv boots gone and the cv joint is grinding. If she's lowerd you mite go with axels better than factory.www.tciauto.com or the axel shop .com (i think?). If you swaped motors sometimes the shafts arnet long enough and will pull the boot apart. If its lowerd sometimes it puts undo stress on the axels and wears then out quick! </TD></TR></TABLE>
This is why you read the post first, then put up you .02
Old 07-22-2003, 05:51 AM
mycvc8u2's Avatar
axle/cv
Old 07-22-2003, 11:49 AM
Default Re: Wierd loud clicking noise from front left wheel well?!?! (mycvc8u2)
can you people read?
Old 07-22-2003, 11:56 AM
NonovUrbizniz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycvc8u2 &raquo;</TD></TR><TR><TD CLASS="quote">axle/cv</TD></TR></TABLE>
I think you meant to say....
"working on 95%"
Old 07-22-2003, 11:59 AM
COMplex.'s Avatar
Default Re: Wierd loud clicking noise from front left wheel well?!?! (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">
"working on 95%"</TD></TR></TABLE>
haha seriously. i had the same problem and i thought it was something suspension related, but low and behold, i had one lug tight, 2 loose and one missing. how dumb did i feel? very. lol
Sorcin
Suspension & Brakes
05-19-2010 05:16 PM
basmasta7
02-18-2010 03:32 PM
carbonlaced
06-27-2006 10:02 AM
Sephro
10-11-2002 10:34 AM
Quick Reply: Wierd loud clicking noise from front left wheel well?!?!
