Wideband O2 sensor - Honda-Tech
Wideband O2 sensor
Old 03-08-2010, 09:44 PM   #1
BEATurBOYS's Avatar
Default Wideband O2 sensor
Im building a sohc turbo. I have an air fuel gauge for it but i read without a wideband O2 sensor its just a light show.
So where is a place that sells it for ek's?
I google and didnt find anything solid.
Also read that the K seriesO2 sensor is a stock wideband. Could those be used on ek's as well?
BEATurBOYS is offline   Reply With Quote
Old 03-08-2010, 11:23 PM   #2
thumper64's Avatar
Default Re: Wideband O2 sensor
look on eBay for Bosch LSU, they are $50 new. If the K series uses a wide band, that may work. I believe the Civic HX in the EK had a stock wide band.
As the sensors are used, they very gradually become lazier and they won't appear worn out until they are very very worn out. Basically, spend a few bucks more to get a new sensor to protect your expensive investment. No reason to cheap out on engine management.
thumper64 is offline   Reply With Quote
Wideband O2 sensor Sir001 Engine Management and Tuning 3 02-12-2017 08:21 AM
Nissan 5 wire O2 sesor, wideband or not? DEMNTD1 Tech / Misc 2 03-01-2006 01:07 PM
Cheap wideband O2's? KStuned Forced Induction 10 05-22-2004 11:19 PM
wideband 02?? JDMlyfestyle Honda Civic / Del Sol (1992 - 2000) 9 03-30-2004 10:48 AM
looking for Stock O2 sensor accuracy Renegade Acura Integra Type-R 5 02-11-2002 04:28 PM
Tags
02, 91, 97, crx, del, honda, installation, o2, replacement, sensor, sol, solwideband, tech, tsx, turbo, turboi, wideband
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
