why is my car so gay?
Location: Your really lame if you dock my points, WA, 98033
today my battery died. its done this before, i have had it charged about 2-3 times
already. i dont drive my car very much only to and from school aprox 3-4 miles round
trip 5 days a week. and i barely drive it on the weekends. k anyway so when my battery
was about to die my gauge cluster tach went out but the mph was still going the tach
would kick on and then shut out along with my radio. well after i got my battery
charged the idle became iratic, and flucuating. before the battery died, only 1hr-2hrs
before the idle was perfect at 800-1000. its throwing a 14 iacv but i had just cleaned i
it out almost a month before. also when i pull the iacv plug the car keeps a steady
idle really low at about 2-300 rpms but it does not die. Whats going on?
thanks for your help in advance
Re: why is my car so gay? (Jumpmann23)
btw the car is a 1996 honda civic dx w/ 99 b16a2 with kenji jumper harness and chipped p28
how old is that battery ? if you haven't already I suggest getting a new one...they do get to a point where they wont hold a charge for ****.
Re: why is my car so gay? (Prod)
i think the battery is about 3 years + old not exactly sure, but when i took it to schucks to get charged the dude said it held a charge. but its probably gonna die again. i think i might buy a new one soon or have my charging system checked
Unceasing Measure
left upper corner right above the shock tower tophat...follow the battery terminal wire that isn't red.
That aside, it's probably your alternator. Get a new one.
Re: why is my car so gay? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">left upper corner right above the shock tower tophat...follow the battery terminal wire that isn't red.
That aside, it's probably your alternator. Get a new one.</TD></TR></TABLE>
couldnt of said it better myself
Re: why is my car so gay? (EGinNY)
*update*
well i fucked around with the car a little bit. got the idle back to normal EXCEPT for when i first start it. when i first start it the idle likes to jump around a bit untill i give it some gas then it comes shooting down to about 800-1000 and just stays there like normal. also i got the code 14 to go away. but now im stuck with a check engine light thats not codeing.?
Re: why is my car so gay? (92lxsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lxsedan »</TD></TR><TR><TD CLASS="quote">question, have you checked your ignitor?</TD></TR></TABLE>
No i have not, i should probably check that as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jumpmann23 »</TD></TR><TR><TD CLASS="quote">*update*
well i fucked around with the car a little bit. got the idle back to normal EXCEPT for when i first start it. when i first start it the idle likes to jump around a bit untill i give it some gas then it comes shooting down to about 800-1000 and just stays there like normal. also i got the code 14 to go away. but now im stuck with a check engine light thats not codeing.?</TD></TR></TABLE>
let me rephrase that.. the idle jumps around and stays jumping around untill i touch the gas. so i didnt touch the gas at all it would just jump around and be irratic all day...
Re: why is my car so gay? (P h i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P h i »</TD></TR><TR><TD CLASS="quote">damn yoo need some cleaning to do</TD></TR></TABLE>
hahah yes deffinatly. but its the least of my problems right now.
ask the dude to do a alternator check by unplugging your battery AFTER you turn your engine on. if it stays on your alternator is still good, if not your alternator is bad.
Re: (kwik2nec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwik2nec »</TD></TR><TR><TD CLASS="quote">ask the dude to do a alternator check by unplugging your battery AFTER you turn your engine on. if it stays on your alternator is still good, if not your alternator is bad.</TD></TR></TABLE>
right on
right on
Re: (branch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by branch »</TD></TR><TR><TD CLASS="quote">your cars not gay... it's just a piece of ****.</TD></TR></TABLE>
Hey, at least his starts.
Re: (branch)
AHAHHA thanks man
AHAHHA thanks man
johnson384
03-12-2016 01:44 AM
motegicivic
05-06-2012 12:02 AM
antig24
06-27-2009 10:27 AM
