white tip spark plugs... normal? - Honda-Tech
Old 08-26-2011, 02:26 PM   #1
Default white tip spark plugs... normal?
Ok so I decided to check my spark plugs... and the tip where you gap it is grayish/white.... according to my search. That means I'm running lean.....and its grayish/white. on all spark plugs..... the thing is I have a 1998 hx swap d16y5... and its a lean burn motor.. and its swapped in legit running the correct ecu......... since I'm running this lean burn motor.. does that mean that its normal for my spark plugs to show grayish/white.?
a little more info the threads have a black stuff on it... but its not on the tip of the spark plug.. its just on the threads....... o yea i took pictures after i cleaned them so you may not see it clearly
UPDATE.... 2 plugs have very little oil on the washer portion of the plugs... JUST THE WASHER has oil on it
milkwasabadidea is offline   Reply With Quote
Old 08-26-2011, 03:24 PM   #2
Default Re: white tip spark plugs... normal?
Light tan or grey is normal, your look black, either carbon.
http://www.gnttype.org/techarea/engine/plugs.html
motegicivic is offline   Reply With Quote
Old 08-26-2011, 03:42 PM   #3
The Grumpiest
grumblemarc's Avatar
Where do you see white?
grumblemarc is offline   Reply With Quote
Old 08-26-2011, 04:00 PM   #4
The part where you gap it looks gray white.. then its black at the threads
Old 08-26-2011, 04:05 PM   #5
Quote:
Its white on the tip where u gap it.. but its black near the threads... I sea foamed the motor not too long ago... but jus through the gas tank
Old 08-26-2011, 04:08 PM   #6
The second picture shows a little white on the tip where u gap. But the threads and circle part is black. So I have no clue what going on... I'm changing it soon though after I sea foam it
Old 08-26-2011, 04:15 PM   #7
Jus went on ngk website. Looking at the chart, my spark plugs seems to be normal apparently... .. mayb slightly running rich..
Old 08-26-2011, 04:20 PM   #8
Your spark plugs are perfectly normal, white means its running lean and is not good.
mathewb20 is offline   Reply With Quote
Old 08-26-2011, 04:47 PM   #9
Quote:
it was white/gray before i cleaned them... so they look a little better....
im running a lean burn y5 motor.... isnt it supposed to show lean since its a lean burn motor?
Old 08-29-2011, 06:10 PM   #10
update... i have very little oil on the spark plug WASHER and washer alone... nothing else
Old 08-29-2011, 07:39 PM   #11
The Grumpiest
Running lean and a lean burn motor are not the same things. Your plugs are fine. Move on.
Old 08-29-2011, 09:08 PM   #12
Master Detailer
98civdx's Avatar
They look okay to me, now that you have them out, might as well replace them. They don't cost more then a few bucks.
98civdx is offline   Reply With Quote
FL 1990 Civic Si /w B17 - Street/DD - $5000 (Username pic added) 10cjennings Vehicles for sale 7 03-05-2016 01:50 PM
☆1crazyk k20 teg build☆ 1crazyk Appearance Build Threads 360 12-28-2013 07:36 AM
T3KNiQe's FA5 Build T3KNiQe Honda Civic (2006 - 2015) 33 09-15-2011 07:55 PM
Need to buy new snowboard gear SALE! jdmb16acivic For Sale 12 10-24-2010 08:36 PM
FS: 99 White 4 Door Honda Civic EX bard GSR 2.0 wes7side5o Southern California (Sales) 30 10-20-2010 07:46 PM
Tags
accord, black, civic, gray, honda, ip, plug, plugs, spark, sparkplugtipiswhitehonda, tech, things, tip, tips, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
