P0301, P0302, P1300 1996 D16Y8 220k Miles, How have you fixed it?
Old 08-21-2011, 11:39 AM
Kohen's Avatar
Default P0301, P0302, P1300 1996 D16Y8 220k Miles, How have you fixed it?
1996 Civic Coupe EX, D16Y8 with nearly 220k miles.
code definitions:
P0301 No. 1 Cylinder Misfire
P0302 No. 2 Cylinder Misfire
P1300 Random Misfire
~~EDIT~~ DRY COMPRESSION TEST- 1: 142psi 2: 20psi 3: 20psi 4: 138psi
i've tried brand new plugs, brand new wires, newer cap and rotor from my other ek, this stuff called seafoam that you dump into your gas tank which is supposed to clean your injectors and all that crap, premium gas.
symptoms: hard to start, gets pretty hot after running, it's been leaking oil for a while now i put a quart in every few days, rough/low idle, dies every once in awhile especially when taken out of a higher gear unless i give it some gas, sounds like it's missing, have to give it a lot of gas to get it going from 1st gear, trouble going up hills, trouble accelerating...
anything helps, thanks!
Old 08-21-2011, 11:45 AM
The Grumpiest
grumblemarc's Avatar
Default Re: P0301, P0302, P1300 1996 D16Y8 220k Miles, How have you fixed it?
220K with problems? Get a new engine.
Old 08-21-2011, 11:55 AM
Kohen's Avatar
yeah i have a y8 with 180k that runs like a champ i'm probably gonna put in if i don't get this GSR
Old 08-21-2011, 01:34 PM
sde780's Avatar
does it smoke?
Could be a headgasket. Also is your ignition & mechanical timing good?
Old 08-21-2011, 01:37 PM
Former User's Avatar
Compression test the cylinders.
Old 08-21-2011, 01:45 PM
Kohen's Avatar
yes. lot's of blue smoke. forgot to mention that. i was also thinking a blown headgasket
and i will be testing my timing soon.
yeah i probably should do a compression test.
Old 08-21-2011, 02:08 PM
Kohen's Avatar
i only tried Seafoam through my gas tank. perhaps i should also try it by mixing it with my oil?
edit: or maybe a vacuum line, from the brake booster?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/guaranteed-way-increase-your-horsepower-10-minutes-seafoam-1502112/
http://www.seafoamsales.com/how-to-u...treatment.html
Old 08-21-2011, 02:17 PM
Master Detailer
98civdx's Avatar
Lots of blue smoke leads me to say pistons rings need to be replaced.
When you check the timing, make you sure you the mechanical timing first, than set ignition timing.
Old 08-21-2011, 02:28 PM
Kohen's Avatar
alright, will do.
Old 08-28-2011, 09:30 AM
Kohen's Avatar
JUST DID A DRY COMPRESSION TEST- 1: 142psi 2: 20psi 3: 20psi 4: 138psi
Old 08-28-2011, 11:26 AM
sde780's Avatar
you can thank seafoam for that
Old 08-28-2011, 03:17 PM
Kohen's Avatar
for what?
Old 08-28-2011, 08:35 PM
Kohen's Avatar
soo, blown headgasket, right?
Old 08-28-2011, 08:36 PM
Possibly. Do cylinder leak down tests to verify or refute.
Old 08-29-2011, 08:38 PM
Kohen's Avatar
i'll be putting the new headgasket in, here in a couple days and let you guys know how that goes.
macson
09-24-2009 06:48 AM
answerd
04-15-2008 10:20 PM
boss96ek
02-02-2008 12:37 AM
fjuman
19
09-01-2004 06:05 AM
deadeyehatch
03-08-2004 11:49 AM
Quick Reply: P0301, P0302, P1300 1996 D16Y8 220k Miles, How have you fixed it?
