White SMOKE!!!
White SMOKE!!!
White smoke...I just finished fixing up my car because of a recent headgasket problem. I have replaced almost everything, new headgasket,valve seals, exhaust and intake gasket,water pump and timing belt. I also did resurface the head and torque everything to specs. The coolant level was ok and oil level is ok and it's not milky like when i had that blown headgasket.I'm afraid to drive it around because of the thick smoke that's coming out of the exhaust.need help pls.
Re: White SMOKE!!! (superfast666)
was the HG bad when you did all this work? If so how long did you let it run? I just changed mine and if you still have a lil water in it then you have to let it burn it out. I let mine idle for about 20min to let it heat up and get a good seal and it smoked but after I let it cool down and started it up again it seemed to be fine.
