Where is the PCV valve in civic 98 lx? - Honda-Tech
Old 01-31-2012, 12:56 PM   #1
Default Where is the PCV valve in civic 98 lx?
1998 Honda Civic LX, 195k
I want to clean the air induction system but I have a question, where is the PCV valve?, What are the points to be checked in the system?
thanks
dishjuarez is offline   Reply With Quote
Old 01-31-2012, 01:10 PM   #2
Steezer's Avatar
Default Re: Where is the PCV valve in civic 98 lx?
thanks
if im not mistaked the pvc is on the fuel rail
Steezer is offline   Reply With Quote
Old 01-31-2012, 01:17 PM   #3
Quote:
Thanks, can give someone pict's?
or can tellme where search, thanks?
Old 01-31-2012, 01:27 PM   #4
alphalanos's Avatar
PCV valve is under the intake manifold. Easier to see from under the car. Connected to a black metal box looking thing.
alphalanos is offline   Reply With Quote
Old 01-31-2012, 02:37 PM   #5
Wrona's Avatar
u are very mistaken on the fuel rail? what car are u talking about.. not a honda i've worked on has ever had a pcv valve on the rail
Its underneath ur intake manifold best way to get to it is from the bottom
here's the DIY i used when i changed mine for the first time
http://www.diymyhonda.com/civic/gara...acement-d16y7/
Wrona is offline   Reply With Quote
Old 01-31-2012, 06:31 PM   #6
Simply added to my favorites... thanks
Old 01-31-2012, 06:46 PM   #7
Master Detailer
98civdx's Avatar
You are mistaken.
As said the PCV is a black box under the IM, just above the oil filter.
Do it at the same as you change the oil, it makes it a lot easier without the filter there.
But, you may try from up top, that is how I did mine. The crappy y7 IM will really make you mad doing this, so get ready to swear.....
98civdx is offline   Reply With Quote
PCV valve location EK ? sleeper101 Honda Civic / Del Sol (1992 - 2000) 6 02-21-2007 01:46 PM
Z6 pcv hoses? ILcrxsi1 Honda CRX / EF Civic (1988 - 1991) 3 02-01-2007 09:54 AM
pcv valve location? Turbochargedcivic Honda Civic / Del Sol (1992 - 2000) 3 08-02-2006 09:04 AM
where's the pcv valve briangela1 Honda Civic / Del Sol (1992 - 2000) 4 06-09-2002 11:29 AM
PCV valve? ringgold Honda Civic / Del Sol (1992 - 2000) 17 09-02-2001 07:22 PM
Tags
1992, 1997, 1998, 98, accord, check, civic, honda, located, location, lx, pcv, pcvc, test, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
