Where do these wires from Wiring harness go
I have a b7 wiring harness on my 92 EG8 with a D16Y8 i only have to wires that i cant seem to find a place for
The first wire is the one closest to the distributor plug. it has 4 wires and converts into a Flat metal base with a hole in the middle(obviously a screw goes in there ) but is this a ground or does it belong in a certain place?
The second wire is the longest wire on the passenger side it looks like a ground wire too its a White wire its the longest wire on the passenger side and the last wire as well it seems like a screw goes through the middle where do I bolt this too?
Re: Where do these wires from Wiring harness go (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EG8 »</TD></TR><TR><TD CLASS="quote">I have a b7 wiring harness on my 92 EG8 with a D16Y8 i only have to wires that i cant seem to find a place for
Sounds like the ground that goes to thermostat housing. two wires for fan/two for thermoswitch.
The second wire is the longest wire on the passenger side it looks like a ground wire too its a White wire its the longest wire on the passenger side and the last wire as well it seems like a screw goes through the middle where do I bolt this too? </TD></TR></TABLE>
this one is drawing a blank. Post up a pic. Is the wire thick? I think this might be the starter ground?
Yeah the thing does have 4 wires so i guess its that ground wire for thermostat like u said..
The other wire is thick....its the end of the harness on the passenger side it has a hole in the middle the hole is pretty small seems to look like a ground for somthing
these are the two wires out of the harness of my b7 i cant figure out where they go
This one has 4 wires leading out to a flat surface with a hole for a screws or something in the middle ^^^^
Pretty much a white thick gauge cable that has a circular end with a hole in the middle this one is the longest wire out on the passenger side ^^^^
Global Moderator
Re: (92EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EG8 »</TD></TR><TR><TD CLASS="quote">these are the two wires out of the harness of my b7 i cant figure out where they go
Pretty much a white thick gauge cable that has a circular end with a hole in the middle this one is the longest wire out on the passenger side ^^^^</TD></TR></TABLE>
I believe the wire pictured in the second pic is the starter hot wire.. Maybe a 12mm or 14 mm nut that hold's that onto the starter..
Re: (92EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EG8 »</TD></TR><TR><TD CLASS="quote">Ok its goes on the starter then? Because i only have the positive wiring that goes on the starter and not any ground </TD></TR></TABLE>
Why don't you follow that white wire to where the other end is attached. It could be a chassis ground wire for the trans. The starter is grounded through the trans housing it does not have a large ground wire going to it.
maybe because that wire is part of my WIRING HARNESS...Thats why im asking. its not a loose wires both wires are from a harness
Re: Where do these wires from Wiring harness go (92EG8)
Top picture; ground on thermostat housing (right behind your middle finger!)
Bottom picture: to starter solonoid
Then again maybe not .....Anyone here help me with a picture of exact location I cant seem to find these spots in my car....this is all that Im missing now
Re: (92EG8)
first wire with the SQUARE end goes to the thermostat housing. its secured with a 10mm bolt.
second wire goes to the fuse box. open it up. its the fuse box on the pass side. there are 2 locations where they can go. there is a power (which is the white one you have) and the other is the ground which is probably already in teh fuse box and grounded to the shock tower. that has a little arm on the side of it if you will. the white wire you have goes right next to it.
hope this helps. if not. ill take pics of my car tonight and post them so you can see
thanks i got the white one into the fuse box i forgot about that one ... =] that one worked out great now im not too sure about the thermostat one i see 10mm bolt but dont know which one ...[its near the coolant lines right?
Re: (92EG8)
where the lower rad hose ends on the engine side. there should be an area that will accomodate that square head. it should be a 10mm bolt by itself used only for that wire.
thinkbrianthink
03-06-2003 08:52 AM
