where is the diagnostic plug at on my EK? - Honda-Tech
Old 04-24-2004, 06:28 AM   #1
Honda_Tengoku's Avatar
Default where is the diagnostic plug at on my EK?
Ok U had an EG Civic and have used my diagnostic plug several times. Currently I have a 98 EK Civic and have an H22 in it. I could not find the diagnostic plug anywhere on the bottom side of the passenger dash. Any ideas where that little 2 pin brown connector is at?
Honda_Tengoku is offline   Reply With Quote
Old 04-24-2004, 08:21 AM   #2
h2392si's Avatar
Default Re: where is the diagnostic plug at on my EK? (Honda_Tengoku)
if you're looking for the jumper to look up the chech engine light code then its on the bottom of the passengers side, on the right hand side hidden in between the plastic that is on the right hand side look for it and its there. If you're looking for the real diagnostic connector to look up codes then its on the drivers side underneath the steering wheel a little to the left hand side. peace and keep it safe.
h2392si is offline   Reply With Quote
HOW TO DO A DIAGNOSTIC CHECK MANUALLY. p.b.k Honda Civic / Del Sol (1992 - 2000) 1 06-07-2010 02:27 PM
Diagnostic Plug for OBD2A K I T T Honda Civic / Del Sol (1992 - 2000) 2 12-08-2007 05:07 AM
confirm diagnostic mode? suspendedHatch Honda CRX / EF Civic (1988 - 1991) 5 10-02-2006 11:06 AM
Diagnostics Port BigBlob202 Honda Civic / Del Sol (1992 - 2000) 1 08-02-2004 09:50 AM
OBD 1 diagnostic carl_aka_carlos Tech / Misc 4 09-08-2002 01:34 PM
Tags
1998, 2005, 98, civic, connector, diagnostic, dianostic, dtc, ek, honda, location, locations, obd2, plug, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
