where to buy OEM paint in spray can?
The Grumpiest
Re: where to buy OEM paint in spray can?
I know you didn't even try to search.
http://www.paintscratch.com/touch_up...ray-paint.html
10 seconds on Google.
Any paint shop that mixes up automotive paint should be able to. Give them your paint code and they should mix it up and put it in a rattle can for you.
I use the duplicolor perfect match rattle can in milano red when im painting lips and sideskirts. Autozone sells it, check if they have yours.
Call your local napa. Some napas mix paint, some can put it in a can. Prolly be closer to $20 not $100. I used to work at a napa that did paint in a rattle can.
Almost any parts shop carries Duplicolor line rattle cans. Whether they carry the specific color that matches your paint code is another story...
Given your paint will wear out and fade over the years, you likely won't find an exact match. I have a 2000 VSM coupe and I've tried many options. The duplicolor paint match, going to paint stores to have them professionally matched, etc.. and the results were never the same. Good luck to you, but I doubt you'll get a perfect match to the current tone.
The Grumpiest
Don't listen to any of these other guys. Check out this website. I used it for my car, the **** matched almost perfectly, considering the paint on my car is 18 years old. Grab yourself a 2 oz can of clearcoat while you're at it, and make it last.
Good luck my boy.
Website: http://www.expresspaint.com/
Good luck my boy.
Well you can search up the code on the sticky and you can buy it on amazon for touch up paint and they're right, as long as you give up the code any paints spot can get it for you.
Damon
08-10-2003 03:23 PM
