Where am i leaking from ???
ok so i have a 95 civic d16z6 and it leaves a good sized puddle every time i park for like an hour or so. I have replaced the oil pan gasket and the rear main seal . Now for some info there is oil on my tranny dripping on my exhaust and on my oil pan so what do you guys think ?
Re: Where am i leaking from ???
Perhaps the large o-ring behind the oil filter? (Not on the filter itself, the housing the filter screws to has an o-ring)
Clean it all off, drive it for a bit and see if you can locate the source.
i believe i found out what it is i put my hand under the vtec solinoid and it was dripping oil so im guessing its the gasket
I had the same issue with mine. You might as well replace the oil pressure switch gasket (another dealer item) while you're working on the VTEC solenoid. It is mounted on top of the solenoid.
blacktibby07
21
02-03-2011 04:42 AM
