EK 1.6Vtec low rpm sputter
Old 10-14-2011, 01:55 PM
Bruce_Leroy__'s Avatar
Default EK 1.6Vtec low rpm sputter
As the title says, I have a new egr and distributor. These are my codes: p0303, p0301, p0300, p1399(pending).
When I first got the car it sputtered constantly at lower rpms, but only after the car has been driven for a while. Like warm up time. I changed the fuel filter and it feels and sounds a lot better, however it still sputtered after a while of driving but not as constant. When I looked at the old filter the excess gas came out brown. I assumed that was not good. Anyone have any ideas to help me out here?
Old 10-14-2011, 01:58 PM
joeshmo's Avatar
Default Re: EK 1.6Vtec low rpm sputter
Bad fuel filter can definitely cause this. Replace that first.
Your codes are all misfire codes. P1399 is the random misfire code.
I would replace your spark plug wires, check the condition of your plugs. You say you have a new distributor, which I'm guessing you replaced the cap as well so that is likely not a problem. Plug wires can go bad and cause misfire. Also, are you sure you put the plug wires back on in the correct order? Not doing so will cause misfire and the engine to run rough.
Old 10-14-2011, 04:05 PM
Thx, ill try and check the spark plugs and change the wires tomorrow. I just got the car, but the fuel filter did change the performance of the issue. But didn't fully delete the issue.
Old 10-14-2011, 04:08 PM
Wrona's Avatar
you didnt give enough info about the car i am assuming it is a HX since you mentioned an EGR Valve unless youre in europe or japan which than you do actually have a an EK
Old 10-14-2011, 05:46 PM
Sorry, 98 HX 1.6 sohc vtec all stock
Old 10-16-2011, 10:53 PM
Checked wires and changed plugs. The wrong part number for NGKs were in the engine. Still misfires though, and only misfires when engine reaches normal operating temp. I'm not throwing a code for EGR but I'm gonna check to see if its clogged. Is that possible considering I'm not throwing a EGR code?
RomesEM1
01-27-2010 02:27 PM
h_civ2000
35
10-20-2009 04:15 PM
eternity-type-r
02-17-2009 02:27 PM
B bOy CrAyOn
09-06-2007 08:32 AM
st0nedstoopid
11-03-2003 03:27 PM
Quick Reply: EK 1.6Vtec low rpm sputter
