Wheel Well Thumping
Old 02-08-2006, 02:55 PM
92civichatch1's Avatar
Default Wheel Well Thumping
Ok heres the situation: There is a loud thump coming from the driver wheel well area. Only when there is pressure(meaning its moving). I had the car jacked up and nothin happened but as soon as i turned it while drivin Thump Thump Thump and the tighter it was turned the more often it thumped. It wont do it while drivin straight but on any turn THUMP. NO ratlles, NO pings, NO other noise but a nasty thump.
My guess is either the tie rods and ball joints or strut damper assembly.
Car: 1992 Civic Hatch with LS swap with KYB struts and eibach prokit
Any help will be appreciated guys.
Thanks
Old 02-08-2006, 02:57 PM
ianae86's Avatar
Yeah, a clicking would suggest CV joints. Is it in only one direction or both?
Old 02-08-2006, 03:22 PM
Default Re: (ianae86)
its a thump not the usual click from the cv its a really loud thump. I just looked at it again it sounds as if its somethin moving maybe axel thats gettin caught (thump) then goes again. Could i have cracked my cv joint or somethin?
Old 02-08-2006, 04:16 PM
Default Re: (92civichatch1)
bump help me out
Old 02-09-2006, 12:26 PM
ianae86's Avatar
I wish I could man. I'm really not that in the know. I just suggested the CVs since I had to have them changed in my honda. How low are you riding? Maybe wheel rub in the turns?
Old 02-10-2006, 08:33 AM
Its only dropped as far as the prokit drops it which is like 1' 1/2'' so its not that. Right now i think its the tie rod ends. More specifically the passenger side. there is play there and more than there should be.
Old 02-10-2006, 03:20 PM
ianae86's Avatar
I could see that being a possiblity. I just read that you said prokit before, sorry. I was actually gonna order those springs, haha. Unless you're failry comfortable with working on those components, I would check it into a shop. I kow I'm not and the idea of something being wrong with that important of a component makes me nervous. BUMP FOR ADVICE FOR THIS GUY!!
Old 02-10-2006, 04:18 PM
schardbody's Avatar
your tie rod isnt hitting the crank pulley is it??? just a though, i know sometimes the EK have that probem.
ams185
03-15-2014 10:16 AM
all-mtr-teg
11-28-2010 10:22 AM
B18C-EG
04-17-2008 06:37 PM
Eresuncabron
10
12-12-2003 01:45 PM
Acura97GSR
05-19-2002 03:00 PM
Quick Reply: Wheel Well Thumping
