Wheel shakes...tie rod replacement time? - Honda-Tech
Old 09-22-2006, 11:29 AM   #1
unknown0001's Avatar
Default Wheel shakes...tie rod replacement time?
Hey guys, I'm helping my lady friend get her car running and looking good but when I jacked her car into the air to check out the wheels by shaking left to right the wheel has a small bit of play. Both wheels have this play, but passenger has the most. When she drives the car you can feel the wheel movement actually and it's not safe so I want to have this fixed for her asap.
Now my buddie had the same thing and he replaced his tie rods and then got an alignment and everything was fine so would this fix her issue aswell?
Also isn't there an inner and outer tie rod? How would I know which one(s) to replace?
Thank You
unknown0001 is offline   Reply With Quote
Old 09-22-2006, 11:33 AM   #2
93civicsedan's Avatar
Default Re: Wheel shakes...tie rod replacement time? (Mr.RHTuner)
sounds like the tie rods need replacing. I would replace both inner and outer that way you know they are both good and wont have to deal with them again.
93civicsedan is offline   Reply With Quote
Old 09-22-2006, 12:19 PM   #3
Default Re: Wheel shakes...tie rod replacement time? (93civicsedan)
Quote:
but is there a specific way of knowing which ones are bad? she's a bit tight on money and I want to help her get rid of the wheel issue
thanks
Old 09-22-2006, 12:29 PM   #4
Former Moderator
B18C5-EH2's Avatar
Jack the car up and have someone hold the steering wheel in a fixed position.
Now take each wheel by itself and gently shake it back and forth while watching the outer tie rod, then the inner, and see where the play/movement stops.
Are you sure her axle nuts are tight and have been staked down? that can also cause the exact same motion as a bad tie rod.
B18C5-EH2 is offline   Reply With Quote
Old 09-22-2006, 01:02 PM   #5
Default Re: Wheel shakes...tie rod replacement time? (B18C5-EH2)
Thanks Tom, I have checked the axle nuts and they are on there good and have been notched to prevent comming off.
Anybody know what size wrench's I will need also? I remember my friend having like a 32mm or something that big for the rod - to steering rack
Violenty Shaking Steeirng Wheel....Here's the Breakdown Shaguar47 Honda Civic / Del Sol (1992 - 2000) 9 05-09-2011 09:51 AM
my car shakes! the_dxB16 Honda Civic / Del Sol (1992 - 2000) 9 07-30-2009 08:33 PM
Help On my driver side. VIBRATING AND SHAKING x4thGenCafe Honda CRX / EF Civic (1988 - 1991) 7 09-22-2007 01:55 PM
Bad Tie Rod End hinds90 Suspension & Brakes 14 06-19-2007 12:05 AM
tie-rod shakes... VWkila Honda Civic / Del Sol (1992 - 2000) 22 05-13-2005 03:59 PM
Tags
19, 32mm, bad, civic, honda, replaced, replacement, rod, rods, shake, shakes, stop, tie, time, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
