Wheel bearing question
Old 07-04-2013, 09:24 AM
Fnix's Avatar
Default Wheel bearing question
Looking to replace a wheel bearing. If I buy the hub #3 will it come with the bearing #2 already installed? 1999 civic dx
Old 07-04-2013, 09:39 AM
dafreeeze's Avatar
Default Re: Wheel bearing question
Yes it should just replaced mine and both came with bearings
Old 07-04-2013, 09:40 AM
SpokaneSpeed's Avatar
No. They will come as individual pieces that need to be pressed together.
Old 07-04-2013, 09:48 AM
Fnix's Avatar
So I might as well buy just #2 if my hub is still good and save myself some money or is normal to replace the hub as well?
Old 07-04-2013, 10:28 AM
instrument's Avatar
If you buy #3 youll get #3 in a nice bag.
Unless you mean from a junkyard, then youll get the whole knuckle.
Old 07-05-2013, 04:52 AM
kyden's Avatar
it will not come with the bearing on it. that makes no sense. you have to press the hub in after you get the bearing in the knuckle.
Old 07-05-2013, 04:55 AM
Fliptard's Avatar
s this for the rear? If so, I just buy a pair off ebay for like $50, yea they are ebay and cheap, but I have had ZERO issues with them.
Old 07-05-2013, 04:58 AM
angrysmileyface's Avatar
I dont think it comes with the bearing attached otherwise the image would show it under a part number grouping. Not to mention there is a spring loaded circlip that has to go over the bearing. When I did this, I just reused the hub from mine after I pushed out the old bearing and had the dealership represss in the new ones with my current hub. ( I know the dealership is expensive, but napa's machine shop apparently pushed them in too far last time and they failed after a year)
Old 07-05-2013, 04:59 AM
Fliptard's Avatar
how can you push them in too far? they will only go it so far.....from what I understand
Old 07-05-2013, 05:05 AM
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/replaced-wheel-bearing-but-still-makes-noise-vid-inside-2947133/
Old 07-06-2013, 08:23 AM
Fnix's Avatar
So I need two tools? One to remove the hub and then another to remove the bearing itself? Looking online it doesnt seem like there is an all in one kit, just two seperate tools. Maybe a press is cheaper but then I need adapters.
Creator
04-14-2011 06:03 AM
RacerTim
09-10-2010 05:44 PM
bigdogadam
Honda S2000
13
10-27-2009 03:47 PM
kyorishin
10
04-22-2008 07:40 PM
petergriffen
08-11-2006 08:44 PM
Quick Reply: Wheel bearing question
