what would cause my back tire to wear on the inside? - Honda-Tech
Old 03-16-2010, 07:37 PM   #1
Default what would cause my back tire to wear on the inside?
i just got a allignment and replaced my struts and its still doing it.. im guesssing a bad trailing arm bushing?
724chris is offline   Reply With Quote
Old 03-16-2010, 08:27 PM   #2
redeg666's Avatar
Default Re: what would cause my back tire to wear on the inside?
the alignment guy should be able to tell you why
redeg666 is offline   Reply With Quote
Old 03-16-2010, 08:38 PM   #3
ej8coupegsr's Avatar
sounds like camber wear.. what type of suspension you runnin?
ej8coupegsr is offline   Reply With Quote
Old 03-16-2010, 09:19 PM   #4
alphalanos's Avatar
Quote:
irrelevant. only thing that can cause this is bent parts, or bad alignment. camber is not a major tire killer, toe is.
alphalanos is offline   Reply With Quote
Old 03-16-2010, 11:02 PM   #5
turnsignalandy's Avatar
is it even possible to adjust toe on 92-00 rear suspension? sounds like bent parts
turnsignalandy is offline   Reply With Quote
Old 03-16-2010, 11:12 PM   #6
yeah but you should get even wear with a good toe alignment
boxeocampeon is offline   Reply With Quote
Old 03-17-2010, 02:20 AM   #7
Acuronda_SloTeg's Avatar
yes it can be aligned, the dillweed alignment guy probably didnt notice the toe ends right in front of the gas tank under the back seat area of the car. also check for bent parts like they said. and if you are rollin slammed, im not even gonna answer why its happenin
Acuronda_SloTeg is offline   Reply With Quote
Old 03-17-2010, 04:33 AM   #8
nah its not slammed just on tein stechs. what could be bent in the back??
Old 03-17-2010, 12:27 PM   #9
Quote:
well he really didnt give to much info thats why i kinda went with that.. cuz i used to have the same problem with my hatch.. but as far as the bent part goes some of the more experienced dudes should know
Old 03-17-2010, 03:07 PM   #10
camber takes a long time to show tire wear. Its toe that ****s **** up
Old 03-17-2010, 03:13 PM   #11
Master Detailer
98civdx's Avatar
Quote:
agreed
98civdx is offline   Reply With Quote
Old 03-17-2010, 10:32 PM   #12
camber would be the camber arm that bolts to the inside of the wheel wheel. as far as toe goes, it could be a really jacked up lca or a slightly bent trailing arm. and even like i said before, the toe arm is a high thought suspect
my teal hatch! hamburgler Honda / Acura 15 06-19-2009 02:02 PM
shakes like hell!!!! 19992civichatch Honda Civic / Del Sol (1992 - 2000) 11 01-10-2007 11:42 PM
My ABS light is on... Cxsilx Acura Integra 5 10-14-2006 11:32 AM
Uberdata WakeSpliter Forced Induction 34 03-04-2004 11:53 PM
what is the best way to paint my bumper? its go bondo on it?? gulf imports Honda Civic / Del Sol (1992 - 2000) 3 06-18-2003 12:53 PM
Tags
1990, accord, back, bald, del, honda, inside, outter, pilot, rear, sol, tire, tires, wear, wearing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
