removing driver side door panel help
Old 03-16-2010, 01:26 PM
tallypbplayer's Avatar
Default removing driver side door panel help
so my driver side window will not roll up all the way, once it gets near the top it starts skipping and falling down. i want to remove the door panel because i believe that the window may just be off track, and if i can get it back on with out taking it in i would save a good amount of money.
i am wondering if anyone else has had this problem and know how to go about fixing it. if not then can anyone give me tips on how to remove the door panel with out breaking anything.
thanks for the help.
Old 03-16-2010, 02:04 PM
mavvrik's Avatar
Default Re: removing driver side door panel help
I believe theirs two or three bolts. One is in the dip for opening and closing the door. The other is behind the handle. Take those out than i believe the rest are just clips you gotta pop off. Those are around the entire pannel
Old 03-17-2010, 09:53 PM
BuildTheDream's Avatar
Also in my ek I had to remove the speakers. If you have manual windows take a really small screwdriver and push the clip off that holds on the window handle. Took me forever to figure this out, seperate the panel from the handle a little bit so you can see which way the clip needs to be pushed to come out. Hope this helps
ediction
Honda Civic (2001 - 2005)
13
07-01-2011 12:14 AM
casper.hughes
10-12-2008 06:33 PM
206civic
01-08-2005 11:43 AM
DRAG1320ciVHBKsi
11-29-2002 09:50 AM
Thrillhouse
04-14-2002 11:30 AM
Quick Reply: removing driver side door panel help
