what are symptoms of a bad a/c evaporator - Honda-Tech
Old 03-28-2007, 05:35 AM   #1
FLCivic's Avatar
Default what are symptoms of a bad a/c evaporator
before I spend $$ on a new a/c evaporator, does anyone have any experience with a bad evaporator?? and if so what are signs of a bad a/c evaporator?? or a bad a/c expansion valve??
thanks
FLCivic is offline   Reply With Quote
Old 03-28-2007, 09:18 AM   #2
94hatchling's Avatar
usually the evaporator doesnt just go out.
BUT, if there are issues with it, the problems could be a dirt or debris plugged core, cracked or broken case, or a leaking seal or o-ring. also check to make sure the fins in the evaporator arent clogged with lint and hair, etc that would restrict air flow through it, decreasing its heat absorbing capabilities.
if its the expansion valve, there will be high pressures on the low side. usually caused because the remote bulb isnt making contact with the outlet of the evaporator tube. make sure there is a good mechanical connection between the two and is secured properly. if thats correct, then the expansion valve is defective.
94hatchling is offline   Reply With Quote
Replacing A/C thermostat without removing evaporator vinuneuro Honda Civic / Del Sol (1992 - 2000) 1 09-10-2013 06:56 PM
WTB A/C EVAPORATOR CORE for 98 and up civics 98by911 Want to Buy 1 10-12-2006 05:07 PM
A/C install on a 99 EK integraver Honda Civic / Del Sol (1992 - 2000) 14 09-08-2005 06:29 PM
WTB: 96-00 Civic evaporator , idler pulley and A/C wire harness...urgent! Halo Want to Buy 3 08-21-2003 10:34 PM
A/C Heater core question Boges Tech / Misc 2 07-18-2002 08:21 AM
Tags
ac, bad, broken, car, civic, defective, evaporator, expansion, honda, integra, signs, sympoms, symptoms, sypmptoms, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
