What size door speakers come in a 98 civic ex?
Old 01-25-2012, 06:13 PM
98EJ7Y8's Avatar
Default What size door speakers come in a 98 civic ex?
this may sound dumb but what size door speakers come in a ex
Old 01-25-2012, 06:19 PM
The Grumpiest
grumblemarc's Avatar
Default Re: ? 98 civic
Don't remember off hand but if you're shopping for speakers go here.
http://www.crutchfield.com/S-J2Cn21vBqhJ/
Use it as a guide for fitment only.
Old 01-25-2012, 06:21 PM
98EJ7Y8's Avatar
thanks use to get this mag in the mail a while ago and they have great product
Old 01-25-2012, 06:24 PM
Former User's Avatar
Default Re: What size door speakers come in a 98 civic ex?
Please place simple technical questions directly into the thread title -- Title edited.
Old 01-25-2012, 06:42 PM
motegicivic's Avatar
6 and 1/2 door, 6x9 rear deck.
Note the door is shallow depth, unless you cut the plastic cup.
Old 01-25-2012, 08:30 PM
sde780's Avatar
"Regular" 6.5" speakers don't fit, I read you need the 5.25" ones. I know for sure that my Polk 6.5" components don't fit
Old 01-25-2012, 10:10 PM
Master Detailer
98civdx's Avatar
My Infinty 6.5's fit nicely.
You need to trim the plastic cup out for almost any speaker to fit.
Old 01-25-2012, 10:11 PM
hondamaster703's Avatar
6.5 should fit perfectly.
Old 01-26-2012, 03:06 AM
jbpnoman's Avatar
JL XR and ZR series speakers will require some serious fabrication to make them fit, just FYI, but damn do they sound good.
Old 01-26-2012, 03:53 AM
sde780's Avatar
I stand corrected, standard 6.5" do fit. However "oversize" 6.5" do not, which may be the case with my Polks and several other speakers out in the market. That is not to say 5.25" will not fit; the OEM baffle even has 4 holes to bolt it on.
I knew I read somewhere about 6.5" not fitting...it's the oversized ones that don't.
Old 01-26-2012, 06:56 AM
Well some manufacturers, market speakers as 6.5/6.75 those are typically bigger.
Old 01-26-2012, 09:32 AM
Master Detailer
98civdx's Avatar
This is true.
I had some old kicker ds650's, what a PITA.
The terminals were on the sides, No way of getting them to fit without chopping up the pannel.
But, 9 times out of 10, the baffle, or the "cup" will need to be removed, unless you're speakers are pretty shallow.
Are you sure that isn't that issue? The cup takes minutes to remove.
Masho
Honda Civic (2001 - 2005)
01-08-2012 01:58 PM
HondaCrazy20
Audio / Security / Video
09-05-2005 03:21 PM
Unjockable
12
12-15-2003 10:22 AM
CivHizzle
12-10-2003 03:38 PM
Loveless
02-20-2003 09:38 AM
Quick Reply: What size door speakers come in a 98 civic ex?
