What is this sensor? 98 Civic DX - Honda-Tech
Old 01-07-2012, 11:56 PM   #1
wakawu's Avatar
Default What is this sensor? 98 Civic DX
1998 Civic DX D16Y7 just got it off a friend with a no start issue. Replaced the head gasket and I tried removing this sensor but I yanked on the head by accident and it ripped the sensor in 1/2. What is this sensor for? Does it have anything to do with coolant? Coolant temp gauge in the dash does not move past cold so I'm just assuming.. any help is appreciated thanks
It is located directly under the distributor next to the heater hose.. http://i40.tinypic.com/242sirq.jpg
wakawu is offline   Reply With Quote
Old 01-08-2012, 06:04 AM   #2
Resident Gearhead
BryanM.'s Avatar
Default Re: What is this sensor? 98 Civic DX
Yes that is the coolant temp sensor for the engine temp gauge.
BryanM. is offline   Reply With Quote
Old 01-08-2012, 08:17 AM   #3
Also often called the 1-wire coolant temperature sender/sending unit.
Former User is offline   Reply With Quote
Where does this sensor go?! 98 Civic DX bassysingh Honda Civic / Del Sol (1992 - 2000) 10 10-06-2011 06:18 PM
mini me coolant problems gsxr1k05 Honda CRX / EF Civic (1988 - 1991) 3 09-23-2010 10:07 PM
DX engine swap jsmit428 Honda CRX / EF Civic (1988 - 1991) 2 02-02-2007 11:09 AM
88-91 DPFI to MPFI engine code jsmit428 Hybrid / Engine Swaps 1 02-02-2007 10:14 AM
What sensor is this... tgreaves Honda CRX / EF Civic (1988 - 1991) 2 10-20-2003 10:45 AM
Tags
98, civic, coolant, dx, erratic, gauge, head, heat, honda, location, sensor, sensor98, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
