What is related to a "drive cycle" on OBD2 cars? - Honda-Tech
Old 12-05-2004, 02:19 PM   #1
Default What is related to a "drive cycle" on OBD2 cars?
Smog?
OEM replacement parts?
Let's say you'll need to replace an o2 sensor, would you need to wait for the drive cycle to shut off your CEL for you?
E-brake or Handbrake is offline   Reply With Quote
Old 12-05-2004, 02:54 PM   #2
CaptinMcnut's Avatar
Default Re: What is related to a "drive cycle" on OBD2 cars? (Inconclusive)
a drive cycle is usually like probbly 15 min or so of driving around
CaptinMcnut is offline   Reply With Quote
Old 12-05-2004, 02:58 PM   #3
Kamin's Avatar
Quote:
Smog?
yes, but you can reset the ECU (by removing the fuse) and it will reset the computer. but dont do that and go to emissions because none of your systems have been tested and you will fail.
a drive cycle is a specific list of things that needs to be done for the computer to test all its systems. it involves things like accelerating slowly, quickly, braking, cruising, freeway speeds etc. some can take over 30 minuets to complete.
Kamin is offline   Reply With Quote
Old 12-05-2004, 08:45 PM   #4
Default Re: What is related to a "drive cycle" on OBD2 cars? (Kamin)
Any other information guys? Thank you by the way.
Old 12-06-2004, 05:00 AM   #5
EE_Chris's Avatar
Quote:
What you're listing here are really specific things that must happen in order for the ECU to run a monitor test.
A drive cycle is much simpler - ECT needs to start below a certain threshold, rise above a certain level, then fall below the threshold. I'm pretty sure some other sensors need to show some activity as well, such as the VSS (if the car never moved, it would not be considered a drive cycle).
EE_Chris is offline   Reply With Quote
Old 12-06-2004, 01:00 PM   #6
Kamin's Avatar
Default Re: What is related to a "drive cycle" on OBD2 cars? (EE_Chris)
well there are 2 types of cycles, the standard cycle like you listed and the system readiness cycle.
civic drive cycle? turbod16y8 Honda Civic / Del Sol (1992 - 2000) 7 04-09-2014 04:18 PM
97 ex f22b moniters still NOT ready. PLEASE HELP!! js97f22b Honda Accord (1990 - 2002) 7 07-20-2011 02:02 PM
OBD2 GSR DRIVE CYCLE ferio_boy Hybrid / Engine Swaps 1 07-18-2008 09:10 AM
OBD2A DRIVE CYCLE, HOW LONG DOES IT TAKE? JBirch_97Prelude Tech / Misc 6 04-06-2007 10:42 AM
OBD2 Drive Cycle? JDM R Honda Civic / Del Sol (1992 - 2000) 4 08-12-2004 11:41 PM
Tags
2005, cel, civic, civics, cycle, drive, driving, ecu, honda, mil, o2, o2sensor, obd2, reset, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
