what is the purpose of a knock sensor - Honda-Tech
Old 05-13-2007, 05:38 PM   #1
honda616's Avatar
Default what is the purpose of a knock sensor
could chips that cancel the knock sensor and rev limiter potentially harm the engine? and do you really need the knock sensor, im new to the import world just need a little help
honda616 is offline   Reply With Quote
Old 05-13-2007, 05:41 PM   #2
EM199dcs's Avatar
Default Re: what is the purpose of a knock sensor (honda616)
What is a 'Knock Sensor''?
The knock sensor (KS) are commonly found on modern injection engines (carburetor engines do not have them installed), but NOT all injection engines use a KS. It is a sensor that outputs a small electrical signal on detecting 'engine knock'. Its related to ignition timing and fuel detonation within the cylinder head. On receiving a knock signal, the ECU (Engine Control Unit) will temporarily adjust (retard) the ignition timing to prevent the condition.
Some engine systems with a KS can detect engine knock in an individual cylinder. Timing for that cylinder alone will be retarded by the ECU until knock ceases.
So basically, the KS is used to stop the engine detonating (destroying) itself when the engine is running.
EM199dcs is offline   Reply With Quote
Old 05-13-2007, 05:54 PM   #3
honda616's Avatar
Default Re: what is the purpose of a knock sensor (EM199dcs)
ok thanks, and if i am bolting on a d16y8 intake manifold will i still be able to use my throttle body and fuel rails and stuff on my d16y7?
Old 05-13-2007, 05:59 PM   #4
crispy93's Avatar
yes ma'am
crispy93 is offline   Reply With Quote
Old 05-13-2007, 06:01 PM   #5
honda616's Avatar
Default Re: (crispy93)
is it difficult to connnect everything to the new intake?
Old 05-13-2007, 06:03 PM   #6
Ek Forever y0!
Libertariat's Avatar
Default Re: (honda616)
Quote:
not if you're using an auto manifold.
Auto manifold makes it totally plug and play.
Libertariat is offline   Reply With Quote
Old 05-13-2007, 06:14 PM   #7
honda616's Avatar
Default Re: (ek forever guy)
ok because i have and automatic, and i was wondering when i take the head off and but the vtec head on will the fuel rails and throttle body still be there from my y7
Old 05-13-2007, 06:22 PM   #8
Ek Forever y0!
Not quite sure what you're saying but you can use the y7 tb and injectors.
Old 05-13-2007, 06:58 PM   #9
honda616's Avatar
ok, oh yeah what is the maximum miles you would suggest on a vtec head that i should buy
Old 05-15-2007, 02:17 PM   #10
EM199dcs's Avatar
Well you want below 90K I would look for like 55K miles or less but thats just me. Anything over 90 you dont have a clue how it was driven what is the matter with it various different things.
Old 05-15-2007, 02:30 PM   #11
Ek Forever y0!
Default Re: (EM199dcs)
Call hmotors for a y8 head. Should be decent pricing and you know it'll have low miles.
knock sensor mprelude Honda Prelude 3 05-18-2005 02:20 PM
WTB Plug Harness for gsr knock sensor CrazyHB For Sale 7 09-01-2004 08:17 AM
WTB GSR KNOCK SENSOR CrazyHB For Sale 5 08-30-2004 07:28 AM
I Need a Knock Sensor dustrag For Sale 5 10-17-2003 09:00 AM
Need Knock Sensor!! G3gsr For Sale 3 04-27-2003 08:56 PM
Tags
1992, 2001, accord, civic, fora, function, honda, ignition, knock, nox, pourpose, purpose, sensor, sensors, timing, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
