What is the part number for a plug one step colder NGK plug than for a Y8.
What is the part number for a spark plug one step colder NGK plug than for a Y8.
well whats the ngk part number for a stock one?
a typical NGK number is like a BR7e for example a colder plug would be a BR6E.
so whatever number it calls for stock, just go down a number but keep the letters the same
Re: (prettylew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew »</TD></TR><TR><TD CLASS="quote">well whats the ngk part number for a stock one?
so whatever number it calls for stock, just go down a number but keep the letters the same</TD></TR></TABLE>
You got it backwards.
Re: (994door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door »</TD></TR><TR><TD CLASS="quote">the original plug is ZFR5F-11 so it would be a zfr6f-11. but bkr6 would work</TD></TR></TABLE>
I have 2477 Iridium plugs in the car right now,
Autozone says the regular NGK's V-Power for a Y8 are 2262 so I should pickup a set of 2263 Plugs then?
Says that the ZFR5F-11's are meant for a miata?
Re: (Dasfinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc »</TD></TR><TR><TD CLASS="quote">Autozone says the regular NGK's V-Power for a Y8 are 2262 so I should pickup a set of 2263 Plugs then?
Says that the ZFR5F-11's are meant for a miata?</TD></TR></TABLE>
2262's and ZFR5F-11's are the same plug...
Just ask for ZFR6F-11's, if you want to go one heat range colder.
Re: (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 »</TD></TR><TR><TD CLASS="quote">
Just ask for ZFR6F-11's, if you want to go one heat range colder.</TD></TR></TABLE>
awsome, thank you. I suspect since my compression is in the neighborhood of 10.8:1, I may run better with a slightly colder plug than the normal Y8 Plug, any risks of running to cold of a plug?
Re: (Dasfinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc »</TD></TR><TR><TD CLASS="quote">I suspect since my compression is in the neighborhood of 10.8:1, I may run better with a slightly colder plug than the normal Y8 Plug, any risks of running to cold of a plug? </TD></TR></TABLE>
If they're too cold, they will foul. If it's bad enough, you'll just have to replace them.
Honestly, 10.8:1 isn't really that high. I would try stock plugs and see how they work.
Re: (ddd4114)
I'm using those 2477's right now which are intended for the Y8, just trying to trouble shoot my ignition issue
https://honda-tech.com/zerothread?id=2169158
hondaguyef
04-13-2005 01:01 PM
