what is the name of this and what it does?
Old 01-13-2011, 01:46 PM
speedfreak44's Avatar
Default what is the name of this and what it does?
what is the name of this unit and what is its purpose?
Old 01-13-2011, 01:47 PM
B18CivicEJ8's Avatar
Default Re: what is the name of this and what it does?
Fuel pressure regulator. It regulates fuel pressure.
Old 01-14-2011, 02:03 AM
i am assuming its give me a rough idle, it vibrates the entire dash. i changed the throttle body and all the sensors and also cleaned iacv and still the same problem occurs.
the line seen that is connected to the regulator and the intake manifold, when it is removed the car idles perfect.
what should i do? remove the line or?
Old 01-14-2011, 02:22 AM
First.EG's Avatar
replace it
Old 01-14-2011, 03:42 AM
what psi should an aftermarket regulator be set at?
Old 01-14-2011, 03:43 AM
Crazy Honda Guy
Deetz's Avatar
about 40 psi
Old 01-14-2011, 04:14 AM
thanks guys
Old 01-14-2011, 01:02 PM
guys the lines connected to the top are air lines? so how the regulator actually works?
Old 01-14-2011, 01:21 PM
The Grumpiest
grumblemarc's Avatar
No air in those lines.
Old 01-14-2011, 01:25 PM
The Grumpiest
http://www.howstuffinmycarworks.com/...regulator.html
I recommend you touch nothing under your hood if you cannot identify any of the hardware found there. Get some sort of manual for your car. Make use of Google.
Old 01-14-2011, 01:27 PM
Crazy Honda Guy
Deetz's Avatar
Yes there is! The internal diaphram is vacuum control based off of pressure from the intake manifold
Old 01-14-2011, 01:30 PM
The Grumpiest
I mean in the sense that there is a vacuum (absence of air). They are called vacuum lines for a reason.
Old 01-14-2011, 01:31 PM
Red_Army's Avatar
its a basic air/vacuum diaphragm that sends unused fuel back to the tank. the rest of what grumblemarc sent you will help you. til you get to the reinstall since its on a truck, not a honda.
Old 01-14-2011, 01:55 PM
this is same thing i was wondering.. to me it dont seem to be connected to the fuel rail , but then again i just researched it...
the bottom line is the return line to the tank? so then the fuel line that feeds the fuel rail isnt tampered with when installing a FPR ?
bounty359
03-22-2005 03:28 PM
ActiveAero
11-13-2003 09:35 AM
DropSquadCivic
10-19-2003 03:21 PM
Superdragr45
09-14-2003 10:04 PM
IgniteTeg
05-29-2002 11:08 PM
Quick Reply: what is the name of this and what it does?
